Did it do anything else other than not die?
Alsowhy was hortensse it's name of all things.
Hortennse was the name of one of the members of the WoC Chamber of the Everchosen forum. I forget why it was named after him,
@NIGHTBRINGER please explain fully, and this time seriously, rather than as a joke.
@Lord Agragax of Lunaxoatl is correct, the Hortennse moniker was created in response to a member of the Chamber of the Everchosen forum with the same name. It happened soon after the release of the army book when the character build was first introduced and discussed. At the time, the build did not have a name so people would continually write out something along the lines of "the Chaos Lord with a 1+ armour save, 3+ ward save re-rolling 1's". Simultaneously, this forum member named Hortennse started a huge rant against the build, calling it unfair and broken. The rant turned into a massive back-and-forth thread, which took a turn towards the aggressive (definitely violative of the stricter rules of decorum of this forum). Eventually somebody suggested that the build be called Hortennse and the name stuck; essentially killing two birds with one stone. Not only did the name become the established norm on the forum, but it spread to other forums as well (even though most did not know the origin of the name).
The rant (14 pages) can be found
HERE
It could fly, which was a lot more of a bonus in Warhammer Fantasy than in AoS, and as a Chaos Lord it boasted one of the strongest character melee profiles in the game, so it could do a lot more than just not die.
The build had a lot of flexibility and could be tweaked to fulfill a wide array of needs. Aside from the baseline defensiveness of the build, you could choose to spend your remaining magic item/mount points to bolster speed, leadership (i.e. stubborn), mobility, offense or further bolster defense.
A generalist version of the build could take down nearly every other character in the game, but could also tie up entire units. Along with the infamous Daemon Prince, it became one of the premier lord builds of the Warriors of Chaos army. The Hortennse Lord was definitely more resilient than the DP, but I believ
I will not play against anyone who fields such cheese.
You're too young to be Hortennse, otherwise, I'd begin to wonder.
