Skaven Slave
Clan Moulder
Yes, Murderous Prowess too, although it not nearly as impactful as the other 3 (attacks, poison, ASF). But yes, it does help them out too.Yes, plus their Murderous Prowess. They're pretty hardcore for a core choice to be honest.
Razordons and Skinks can also damage the Witch Elves, but nearly so much as a Salamander or two. It just takes one of those flame templates to hit right to make HUGE difference. Such a tightly packed, small base size, no armour and low toughness unit is the ideal target for the Salamander.Skinks are great for this as well, even just cohorts who can be thrown away after firing at them and probably killing a bunch (or Razordons but I dislike Razordons due to having to use their BS to hit... that said, I've always been pretty unlucky with my artillery dice rolls on Salamanders....)
I think this is one of the key points about both armies. They have awesome, deadly troops in their core section. I wonder how much it would change both armies if for instance the only core choices for Dark Elves were Spearmen/Swordsmen and Archers.... Conversely, I wonder what kind of a difference it would make to Lizardmen to be able to have straight-up Kroxigor in their core choices or even COR.
Makes you thinks doesn't it?
It is an intriguing idea. The core options of an army can really dictate the focus of the entire force.
In the case of the WoC, if you nerfed the Chaos Warriors, you'd see a lot of chariot play and Throgg + core Trolls.
What if Warriors of Chaos had to field Marauder-type troops as their core only?! Or none of their core choices could have any Marks of Chaos?
Interesting thought.
You can probably run it as a house rule![]()
You could house rule it if you were the one playing the WoC army. However, it would probably be a pretty tough sell to tell the Chaos player that he can't use the very namesake of his army!
Marauders are pretty underwhelming this edition. Interestingly, they were the go to option in the 7th edition WoC book. They were so cheap and effective that most people brought a unit (or two) of 50 Marauders with GWs (often with the MoK).
Besides, so far, this tourney is showing that the Chaos Warriors are not the "big baddies" that they are made out to be. True, these are the best of the best, but they are losing to several infantry units at the moment. Of course we'll have to wait until everything is all said and done, but currently they reside in the bottom 5.
I still maintain that the real bread winners in a WoC army are the DPs, Hortennse characters, Skullcrushers, Hellcannons, Chimeras, etc.
