I view at as support during this dark times!Was not sure if I should like or no![]()
Seems like the pain brings out your inner poet...~I foolishly dared to fly too close to the sun on wings of feathers and GW water effects~
Have some support from me, too.I view at as support during this dark times!![]()
LOLSeems like the pain brings out your inner poet...
Yeah, I'm kind of bummed out about it. Especially considering that up until that point it was turning out very well in my opinion.What a pity...![]()
I put them in my display cabinet with my Lizardmen!You got three nice trees out of it
I know... and I like how you adapted it to your situation... really poetic... especially when seeing high temperature is the main cause of both downfalls...
It's GW... I should have know. They make the best models, but some of their hobby supplies are highly questionable.while no one could expect that water effect stuff to be the wax in this story
Thank you kindly my friend!Sorry about the desert oasis disaster (Life just isn't life without tragedies).
On a much brighter note, i looked up the photos of the cottage you've made long ago, and i have to say, it has been AMAZING experiencing the progress you've made on the cottage!![]()
A sad little update.
In progress shot of the desert oasis before the disaster...
First the good, finished the palm trees for my desert oasis...
View attachment 48355 View attachment 48356
And now the disaster. GW's water effects ruined my terrain piece (even though I only applied a thin layer [1-2mm] and allowed it 48+ undisturbed hours to dry). Sadly, the water pool was my first airbrush project.
View attachment 48353 View attachment 48354
Well a quick update. The oasis is officially dead.
I tried hitting the surface with a heat gun. It actually semi liquefied and all the imperfections disappeared. However, once it solidified again some of the imperfections returned, but it was better than before. Spurred on by this marginal amount of success I made a second attempt at it but I must have been a bit overzealous with the heat gun this time around and warped the acrylic underneath.
In hindsight, it would have been better to sand the piece as @LizardWizard had suggested. That was my backup should the heat solution fail, however I did not anticipate the warping of the under layer of acrylic. Live and learn I suppose.
In any event, the piece is no longer salvageable. RIP Desert Oasis 2018-2018.
Maybe I'll make a replacement one day, but for now I'll move onto finishing other projects (projects without water features!!).
Good advice, thank you!Well if nothing else you at least learned something from the effort (as in what not to do next time). Good luck for when you try again!
(You will come out stronger and better than ever, don't worry! Next piece is going to be amazing!)
The trees can. The rest will have to be redone.What you have can be salvaged
They have forsaken us....the Old Ones have a plan.
Don’t throw the rest away. No kidding. I have a plan.The trees can. The rest will have to be redone.
They have forsaken us.![]()
You have a band saw, Yes?
It might involve a bandsaw.
Has it been a week?
Also, how extensive was the warping/melting?
