Lord Agragax of Lunaxoatl
Eleventh Spawning
Excellent job and I'm going to try and match you when I start my undead board.
Will it be a Tomb King board?
Will it be a Tomb King board?![]()
I thought so, until the water effects dried so poorly. I don't really know how to fix it.Looking good!
With the amount of super glue I used to affix it, there is no way I could separate it. Those two pieces are bonded for life.You used an acrylic backer, right? You could potentially pop it out and scrape it down to start over.
A sad little update.
In progress shot of the desert oasis before the disaster...
First the good, finished the palm trees for my desert oasis...
View attachment 48355 View attachment 48356
And now the disaster. GW's water effects ruined my terrain piece (even though I only applied a thin layer [1-2mm] and allowed it 48+ undisturbed hours to dry). Sadly, the water pool was my first airbrush project.
View attachment 48353 View attachment 48354
ThanksIt doesn’t look so bad to me
Nothing wrong with working with cardboard. I've seen masterpieces made from all sorts of materials.I’m a lot better at making things with cardboard than wood.
Seriously though, I was thinking it would be a lot worse. Maybe you could use it as a frozen pond, replace the palm trees with snowy trees as you haven’t stuck them down yet and cover the whole thing with snow-flock? It may not go so well with your Tomb Kings, but it might go well with your Warriors of Chaos as part of a ‘Frozen North’ theme, and would be great when playing wargames near Christmas time!
I don’t get it. Please explain in detail what the problem with the water is.
It is shimmering/shines and it is blue. Not seeing the flaw. Do I need a bigger screen?
Is it the shimmer on the top that you don't like?And now the disaster. GW's water effects ruined my terrain piece (even though I only applied a thin layer [1-2mm] and allowed it 48+ undisturbed hours to dry). Sadly, the water pool was my first airbrush project.
It is much more noticeable in real life than in the picture. The top surface of the water should be shiny, clear and perfectly smooth. In my piece it is neither of these things. Mine looks patchy.I don’t get it. Please explain in detail what the problem with the water is.
Thank you.@NIGHTBRINGER reaches for nothing less than perfection. I remember his cottage.![]()
Add a sign that says "poisionus dont drink" or something, it would explain the shimmer.
Though how is GW's water? I've only used "woodland scenetics" in the past, and never had any issues with that.
It might work, but it might still show through. It is an option though.OK
I see it now. Put another layer of something over it? Maybe some gloss acrylic medium with some blue ink in it to tint it a bit?
It looks like there is some more depth to work with.
Intriguing... I think I will give it a try and let the chips fall where they may.Could you sand and buff out the imperfections? Or is it a semi hard substance?
