hit reply on the bottom right. yes it's only the battalion but thats healing on 5 units isted of 1 and you don't have to roll for saves and you reroll wounds
And I'd have to scrap my entire army & strategy because even the minimum point cost for this is too expensive, so thank you - but I'll keep it as it is currently.
I'll keep the strategy in mind if I want to make a drastic change.
(EotG looks pretty bad stats wise unless you keep it close to your slann to pick between buffs)
(With this change I'd lose one of my assassination tactics and have no use for command points)
(thanks to GW for making batallions do this stuff - that makes my army a variant of the basic cookie cutout Seraphon recipe - whilst my entire point was to be unique)
(for what I've read, that batallion is strong, but you'd have to pick between the benefits, so it may still work with priests)
EDIT: So I opened up the online free warscroll builder, made a thunderquack duckhost (kroxigors are the better alternative, change my mind) so let's see.
Pick savage every turn to get the rerolls on everything except hits
Add astrolith for rerolling hits
the astrolith and engine have synergy with a slann
add balewind and cogs for summoning
battleline = 2 sets of 5 knights and as many skinks as point value will allow for
2k points cookie cutout thunderthighs
aaaaaand I'm not having fun anymore.
delete list.
(Kroxies have 4 wounds a pop, which makes killing them harder and healing them more effective - besides, they CAN have a better damage output than <equal points> worth of razors& handlers - which I believe is 2 - but my point is because of their survivability, and because the cookie comes with a summoning setup, you can just spawn in razors without paying points for them and have them safe behind a cow wall of 2 basties and 3 kroxies, they'll still benefit from the reroll hits, won't need the heals, and are more convenient to get this way)
