Boomer said:2. Move as fast and straight at him as I can. The Stegs would be side by side, and behind one of them (to block the Bolters) would be an Oldblood on a Carny (to go after the Hydra or Moriath) and with the Strikes First blade in case an Assassin pops up.
lupercal said:Boomer said:2. Move as fast and straight at him as I can. The Stegs would be side by side, and behind one of them (to block the Bolters) would be an Oldblood on a Carny (to go after the Hydra or Moriath) and with the Strikes First blade in case an Assassin pops up.
i would not take the always strikes first blade since the assasian will strike before you since he has a higher int. i would just give him good defence and a decent attacking weapon i would also put a unit of CoR in there since they will get across the board faster than saurus and that is all you are looking for in this battle high speed and good power and armour basically heavy calv will do great things with their saves just let them run and as they out pace the EotG they will still stay in the range of the ward save it provides then they will engage and hold the unit for a sec until the stegs can hit with imapct , same with the carno he will hold the unit until another steg can hit on the other side then they collapse on the center he will know what you are doing but should not be able to stop it just like he has been doing ot you
Boomer said:Well he will likely see this but here goes:
1. 2 EOTGs to give mutual 5+ Ward saves to each other and surrounding units...rolling twice for 5's for almost everyone has gotta help...plus each Priest would grant 2 dispel dice each plus 2 more with Diadem of Power, plus 2 Basic = 8 dispel dice. Plus some Scrolls and maybe the Cube of Darkness. Let the other Priest try Uranons T-Bolt on the first turn but he'll lilely dispel that like Hogans Goat. But that shud do something for the first few turns to hold off the insane Magic until I can get my hands on him..
Revered_Guardian said:ya but how does the hornet blade help that? The assassin will strike first anyways...
Corbechev said:Revered_Guardian said:ya but how does the hornet blade help that? The assassin will strike first anyways...
Oh I am not advocating taking Hornet Blade, But putting your Old Blood in contact with an assassin is a calculated risk, he is going first unless you are Chakax, and all he needs to do is roll a 6 to wound to force you to roll a 5+ ward save, 33% chance of living? I don't really like those odds.
Revered_Guardian said:True, but we can slap that dragon in the face with the blade of realities and watch it fall over instantly....poor low LD saps....
