I agree that most tournaments would incorporate such a ruling. As always, things of that nature are entirely up to the tournament organizer. They wield absolute power within the confines of their event, but such power is limited exclusively to their event. Plus, as you said, GW actually allows the use of the model so long as it is rebased and the player does not try to gain an advantage.Well, you're right, but when GW takes an official stand on something in one event, usually it's good for any official tournament from that point, unless specified otherwise.
It still has no bearing on games outside of tournaments (which is like 99.99% of games).
That is pretty harsh!I've also found the rules for GW grand tournament series, which is 40k but gives an idea of GW's stand on the matter: as usual, the base must be the current one... but that said you can modify your model, but you cannot take advantages, and at most you will have only disadvantages.
Example: if your actual model is taller than the regular one and is behind a scenery and the opponent can see you, you still don’t gain LoS. (Which is imo both silly and excessively harsh, but that's GW)
The issue is mainly the second point. If there's a large difference between the current model and the old model, like with Kroak, it becomes difficult to gauge if it is really hidden or not when someone is using the old model. Sure, noone's going to claim the new Kroak model can hide behind a small bush, but what is the minimum height of wall it'd need to be hidden behind a wall? Is a 10cm tall wall hiding it? 15? 14? 16? It's a bit difficult to tell without the actual model.
When size differences become this extreme, you're better of just using the current model (or at least a more suitable proxy), makes life easier for everyone involved and avoids pointless discussions. Just using the correct base size is simply not going to be clear enough in these cases.
But now you are arguing a different thing! We are not debating convenience or ease of use. The point of contention is whether or not the old Kroak model is legal/valid or not.
I mean, the old Kroak model is technicly no longer officially valid. They have at least some kinda point![]()
Kroak is just one of the few examples where the new model is literally twice as big as the old model, and thus makes the old model invalid.
It was fielded and perfectly valid before the new model was released, so unless there is a written rule that explicitly forbids it, it is fair game.
The answer to that question is clear and unequivocal:
Question: Can the old Kroak model be used in games of AoS at GW run events?
Answer: YES! So long as it is rebased to the new standard and the player does not use the size difference to gain an advantage that would not be available if using the new model.
Rationale/Evidence: GW's tournament FAQ explicitly says so.
Question: Can the old Kroak model be used in games of AoS outside of tournaments (i.e. regular games)?
Answer: YES!
Rationale/Evidence: The old model is still an officially produced model by GW and of the same name. It was a valid model prior to the updated model and there is no rule/faq that explicitly forbids its use now that the updated model has been released.
That is (or was) our debate. Unless you have further evidence that you can directly quote, your original premise is without standing. The old Kroak model is legal and valid for the reasons outlined above.
What you're debating now is convenience and that will be subjective. If both models are available to field, yes, the new model is more straightforward to implement. That's pretty obvious and not up for debate. However, there are many reasons why someone might find it inconvenient/undesirable.
- the person already owns to the old model and is either unable or has no wish to shell out money for the new one
- the person has already painted the old model
- the person likes the old model better
- the old model is much, much, much easier to transport. That could be an important factor if a person is travelling a great distance with an already large army.
- the person does not want to give GW the precedent to invalidate old versions of models. Its a very slippery slope that greedy GW will undoubtedly exploit if they feel they can get away with it.
If agreed upon by both players, any house rule can be used. However, we're not talking about that. We're talking about playing a game of AoS using official rules only. A regular game by the book. And in such a case, the old Kroak model can be fielded without additional permission from your opponent.I mean, outside of official events you can do whatever you like anyway![]()
Ironically, it is you that would have to revert to the use of house rules in order to invalidate the old model.
