Lizerd
@Erta Wanderer want to design two wound saurus warriors?
didn't i do that already?@Erta Wanderer want to design two wound saurus warriors?
We got two wound temple guard, but with the kitbashed bloodbowl saurus we could make two wound saurus warriors, so we might have an equivalent to orruks and stormcastdidn't i do that already?
shur i forgot about it to be honestLooks good, but should we also have a 4+/4+ jaw attack?
On its own it is a pretty forgettable attackshur i forgot about it to be honest
meh, "weak" bonus attacks like this have their uses.On its own it is a pretty forgettable attack![]()
Dang that's niceAlright, here is the two wound warscroll
quick fix you have the bights at a 6/6 to hit and wound might want to fix thatAlright, here is the two wound warscroll
Good catch, thanksquick fix you have the bights at a 6/6 to hit and wound might want to fix that
you have the alpha making 2 attacks instead of 1, but the base attacks is 2 on the regular models.Good catch, thanks
Welp time to fix thatyou have the alpha making 2 attacks instead of 1, but the base attacks is 2 on the regular models.
hmmm well it's definitely not what i wrote this is what i hadIs the Greatblade statline the same as it is now in our book? Otherwise it doesn't look that attractive with the same hit and wound as the spear, but less attacks, with only 1 more damage. Overall, it does have the same potential, but I think giving a heavier blade more rend/better damage (3?) Could give more variaty?
Just a thought.
Otherwise, I think most od the old abilites are fine if the statlines of the models are brought into line. I could see changing the wording on the Scar Vets to be "unmodified" rolls of a Six, as most abilites are moving towards that.
