Lord-Marcus
Sixth Spawning
Because with the 100 years war frames from WarGames Atlantic, that is actually a possibility. If you look carefully, the flow joinery is all placed in places that can be clipped and clipped from the frame itself so that you have each element only suspended by its flow joins under the inbuild base. The exception to this is the casualty figures.Why are pai ting in frame out of curiosity?
It certainly worked out well with this test. I was mostly playing around tonightFor sure looks like a good sprue design especially if you wanted to spray a basecoat on everything
