TOW Pair tournament 1000+1000 with Bretonnia
Ripperdactyl
Kalisto
460
186
43
Well soon we will have a pair tournament and I wonder as usual to some suggestions.
The rules are the following
1000 points army each, both can have general bsb and influence each other units. Heroes can also been in each other units.
No restriction, rare 30%, monster slayer works only on flying monsters (so no carnosaur or stegadon!)
- you can use each other magical items as you wish!!
-some scenario will have scoring units (close order, US minimum 14 and banner)
This is my list idea.
=== Lizardmen [874 pts] Warhammer: The Old World, Lizardmen ===
++ Characters [500 pts] ++
Saurus Oldblood [390 pts] - Hand weapon - Heavy armour (Scaly skin) - General - Carnosaur - FRONTIER AXE - Talisman of Protection - Armour of Meteoric Iron
Skink Chief [110 pts] - Javelin - Light armour (Calloused hide) - Shield - Terradon - Ruby Ring of Ruin ++ Core Units [374 pts] ++
14 Saurus Warriors [224 pts] - Hand weapons - Shields - Heavy armour (Scaly skin) - Shieldwall - Spawn Leader (champion) - Standard bearer
10 Skink Skirmishers [50 pts] - Hand weapons - Javelins - Shields - Light armour (Calloused hides)
I am not sure how about what to do with remaining points but probably: more skinks, some more saurus or 3 terradons.
The idea is that he will play Exiles with level 3 caster, one bombard, duke or paladin on pegasus with glyph necklace that will give MR 2. A big realm knights unit.
An alternative to ruby ring would be Exiles magic items (wand+vial), both give once a game a fireball power level 3 and the vial once a game a flame attack (as a salamander). But they would cost 35 points so I should remove both javelin and shield.
Omg the frontier axe is ridiculous!
If the unit strength of 14 is required to score, don't you need a Saurus block better than that in case some die? Or is it the original starting strength?
I agree =)
The balancement is just bananas with the new arcane journals...
I should have specificied that is the original US that counts. That the reason i won't pla ya lot of saurus since they cost a lot and don't do a lot.
I agree =)
Well true but they still need to be alive at the end, also you still have 126 points left which doesn't buy you something truly useful like a bastiladon with a solar engine. I think I would either
a) drop the skink chief and get an ancient stegadon, or
b) put the remaining points into the saurus unit, maybe get spears and shieldwall, and try to ensure they are there to score. I doubt brett infantry will be!
Also I'd maybe give the skink a BSB... no sure about that though.
a) Is a good suggestion i haven+t thought. I'll think about it.
b) Bretonnia will have both an infantery and a realm cavalry as scoring (just close order). So don't really need a BIG saurus unit, just one more scoring unit. Shieldwall was of course in my considerations =)
The only problem is that if i remove the skink hero i can't play terradons, and it depends a bit if Bretonnia will play a lot of pegasus or not.
