Salamander
discomute
Would not have picked that!Units with S3 T3
Good info thanks
Posting this analysis here in case anyone finds it helpful.
Could you please make some tests (if they are automated) with Carno + Aura of Quetzl alone and with the Bedazzling Helm. I'm still trying to find what could be better - saves or reducing hit chance (considering our low WS and Ini).
Do you mean, one with only Aura of Quetzal, and one with only Bedazzling Helm? I'm not sure I understand. Can you just post the two builds you want me to use? It is automated, so I should be able to plug it in easily.
Yep, exactly. Both great weapons, one with Quetzal + Helm, another one just Quetzal
I'm not trying to be difficult, but I don't think that setup will get at what you want...both setups still have a 4+ armor save. The helm improves the oldblood's armor save from 5+ to 4+, but you have to choose to use either the oldblood or the carnosaur's save, both of which are 4+. Or maybe I still don't get what you're trying to test? Sorry if I'm misunderstanding.
No worries.
I'm trying to find what would be more effective - tanking while reducing the opponent's chance to hit us with Aura/Helmet or with Ward/Armour saves.
My fav combos for the COB are
(possibly adding burning sword as an option in case ethereal is around) (54 points/59 points)
Here you go, hope this helps:
It's worth mentioning again that this number is an efficiency score (somewhat more complicated than this and scaled up to be meaningful, but essentially how much combat res is being generated per point). The version with the bedazzling helm having a lower score than without doesn't mean it fights worse, it means the improvement in combat capability wasn't proportional to the increase in point cost.
- 16.403 - Saurus Oldblood on Carnosaur - Great Weapon
- 20.339 - Saurus Oldblood on Carnosaur - Great Weapon, Aura of Quetzl
- 19.976 - Saurus Oldblood on Carnosaur - Great Weapon, Aura of Quetzl, Bedazzling Helm
- 21.797 - Saurus Oldblood on Carnosaur - Great Weapon, Aura of Quetzl, Talisman of Protection
- 22.143 - Saurus Oldblood on Carnosaur - Great Weapon, Armor of Silvered Steel, Talisman of Protection
- 20.664 - Saurus Oldblood on Carnosaur - Great Weapon, Armor of Silvered Steel, Aura of Quetzl
- 18.342 - Saurus Oldblood on Carnosaur - Sword of Might, Bedazzling Helm, Shield, Hide of the Cold Ones
Here is the raw fightiness-metric, in case you'd rather have that:
This metric doesn't take points into account, and is just how well they fought relative to other builds. AFAIK the best overall performers are still the ones from my first post.
- 6.151 - Saurus Oldblood on Carnosaur - Great Weapon
- 7.221 - Saurus Oldblood on Carnosaur - Great Weapon, Aura of Quetzl
- 8.290 - Saurus Oldblood on Carnosaur - Great Weapon, Aura of Quetzl, Bedazzling Helm
- 8.392 - Saurus Oldblood on Carnosaur - Great Weapon, Aura of Quetzl, Talisman of Protection
- 8.503 - Saurus Oldblood on Carnosaur - Great Weapon, Armor of Silvered Steel, Talisman of Protection
- 8.142 - Saurus Oldblood on Carnosaur - Great Weapon, Armor of Silvered Steel, Aura of Quetzl
- 7.557 - Saurus Oldblood on Carnosaur - Sword of Might, Bedazzling Helm, Shield, Hide of the Cold Ones
You have blown my mind. This changes quite a lot. Yes I did think of taking a great weapon with a monster slaying sword. Or even just our obsidian weapons most of the time. But you can't. Wow.If you have a magic weapon - you _must_ use it and can't switch to a normal one unless magical is destroyed. So I recommend taking at least a sword of might if you will face ethereal opponents. If you need fire damage, I recommend frog's venom - fire + poison.
So here is question for anyone, do you prefer the Ogre Blade or the Blade of Revered Tzunki better?
Why no protection? You can still have a talisman of protection and an armour save of 4+. It’s not a big armour save that’s true but you have the ward save. And you are much stronger against tanky leader on dragonsBoth - 65 points. So no points for protection, and with our Init - waste of a hero.
I would say Giant Blade or Sword of Might. Cheap and leaves some points for protection, even for a Scarvet.
I like it safe too. But if you cannot stop a dragon and you cost 400 points you are doing it wrong. Then just better to have it on a cold one. Pretty deadly, better armour save and lower cost.Ofc you can. I'm just not sure that it's effective - check the table of points effectiveness a few pages ago. But - maybe I'm wrong, I just prefer to play safe with an Oldblood, because he is usually my general.
Just a question… no one thinking to play revered tzunki blade+ talisman of protection?
