Killer Angel
Prophet of the Stars
My thinking is if you are sending out harrier squads of 3 Terradons to gum up your opponent for a turn or two, and are using hunters steed and Cogs, then yes you could go with javelins, since you will drop them from the sky and hope to roll >6” for your charge.
if you are going 6 or more, you probably don’t want to risk a deep strike + charge (and likely won’t be able to drop many bombs anyway) so bolas serve you better here, most likely.
totally agree.
yes, 3 terradons that act as annoyance / distraction / objective grabbers, can certainly be deep-striked and just deal some shot.
but terradons that are played to drop the deadly cargo, simply cannot be teleported, popping at 9" from the enemy: to drop the bomb they need to fly over the target, so the distance they had to cover is 9" + 2" (their base) + ?" (the size of the enemy unit). Unless you are aiming a unit of 1" base models, placed in a convenient conga line, you will need to roll more than 12 on your charge. Even with cogs and hunter's steed, it's a heck of a roll.
