Killer Angel
Prophet of the Stars
Problem is you are feeding resources into it that would better be spend elsewhere. We are absolutely spoiled for options for Serpent Staff, Saurus Warriors, Saurus Knights, Rippers, Terradons and Skinks are all way better recipients. Same goes for command points. The footprint is small, and it's not killy enough. It's durability does not really help, because any opponent with half a clue will just leave it alone.
Bastiladon is still viable for casual play, but I suspect it will already run of of steam if you are playing in a harder local meta.
Thunder lizard bastiladon is probably the only viable build.
