Tutorial Matched Play List GHB2019
But its only 9 Seraphon Units. The Knight Incantor does not count. :)
Huh, where in the deployment rules does it say that Ally units do not count towards on table deployments for reserves?
My book is stored at my wargaming clubhouse.
The models need to be part of the Dracothion´s Tail battalion.
"You can set up 1 reserve unit waiting to appear at Kuoteq´s command for each unit from the same battalion you set up on the battlefield."
Ohh, might have to leave all 3 units of Saurus Knights on the ground then. I was operating under the assumption that it followed standard deployment rules.
Wait...
It's in a faq or is written that way in the GHB2019?
...because in my italian version there's not such a limitation and it wouldn't be the first time that translations are incorrect.
Wait...
It was added into the GHB2019. It wasn't in the 2018 ed, it might not have been updated correctly in Italian. It is also part of the core rules that you can only place a unit into reserves for each unit that is already deployed on the table. Still trying to find this rule's location. Crawling through the FaQ's and errata/designer commentaries today.
Ah, good to know.
And that suddenly creates new problems to the list i was planning to play this weekend... :p
2000pt Fangs of Sotek
Allegiance: Seraphon
- Mortal Realm: Ulgu
LEADERS:
Slann Starmaster
(260)
- General
- Artefact : Miasmatic Blade
Saurus Astrolith Bearer (160)
Saurus Oldblood on Carnosaur (240)
- Artefact : Doppelganger Cloak
- War Spear
- Artefact : Sword of Judgement
Saurus Sunblood (120)
Skink Starpriest (80)
UNITS:
40 x Saurus Warriors (360)
- Spears
10 x Saurus Warriors (90)
- Clubs
- Clubs
10x Skinks (70)
-Boltspitters & Star Bucklers
BATTALIONS:
Fangs of Sotek
(70)
Sunclaw Starhost (130)
Endless Spells/Terrain:
Balewind Vortex
(40)
Chronomatic Cogs (80)
TOTAL: 2000/2000
EXTRA COMMAND POINTS: 2
WOUNDS: 120
This is the list I use for friendly 2k games. I love Fangs of Sotek, but this is not a list I would bring to a tournament. In terms of tactics try to make sure one of your 10 man Saurus units is in you first wave. When possible you want to aim for your 40 man spear unit to be the second wave. This to help make sure you are the one charging and are best able to select order of combat.
Keep your Canros, Sunblood and Skinks Starpriest near your spears. When you have found a favorable combat for your spears then use your Carnos' and Sunblood's command abilities to buff the 40x Saurus Warrior unit.
This list has a remarkably strong match up vs Demons of Khorne and Demons of Nurgle.
Changes from GHB2018 to GHB2019:
  • Lost 20x Saurus Warriors
  • Lost 4x Razordons
  • Added Scar-Veteran on Carnorsaur.
  • Added 10 Skinks
Return to Index
Hey, Lizwiz, wouldn't FoS be better with a bastiladon? I was wondering that, thanks for your work man
Everything is better with a Bastiladon. The question becomes what you give up to include it. The ScV on Carno and 10x Skinks can certainly be dropped to add one. All the second Carno adds is a meaty body and exploding 6's for the 40x Warrior unit. I think you might get more benefit by adding in Razordons though.
FoS is really just a fun Warrior themed platform. My list is far from the most optimized version of it as it does little to take advantage of the extra movement battalion buff. I think the best way to wield it with MinSU warrior units as a tax for being 1 drop with extra artefacts.
You could drop the cogs and skinks for some razordons to add a bit of shooting (6d6 and rerolls is nothing to scoff at). I do believe though that the scar veteran is much more optimal then a bastiladon in a FoS, simply because of those extra attacks meaning anything will get gutted by the warriors.
True, FoS does offer some movement + cogs, but wouldn’t some shooting be of greater benefit?
Would you be able to craft a FoS worthy of bringing into a tournament?
The main short fall of FoS is the amount of tax the battalion requires. The platform itself is rather useful for the 1 drop and extra movement. Essentially, if you want to do well with FoS at a tournament it won't be warrior based. You could potentially do something fun with Carnosaurs and cogs to get turn one charge reach. Perhaps a Terradon version of Fos could allow for turn one Rock drops to snipe supporting heroes.
Most of the things I would do with FoS are done better with DT. Thus, the primary attraction of the battalion to me is that it makes Saurus Warriors usable. The list posted to this thread is the one I use when helping AoS players improve their games.
When i play FOS i literally kill nothing and just throw bodies at objectives for 5 turns.
Usually i can get out to such a big lead by the time you lose everything your opponent cant come back.
Its a questionable way to play the game but i dunno how else you can win with saurus. This is the only thing that seems to work at a competitive level and even then its a rough go.
FoS is interesting to say the least. I would say that against daemons that have to go in Melee (slaanesh, khorne, burgle) it does ok. If you can get reroll saves of 1, or just rerolling failed saves warriors become decently tough for their price point. However if you want better staying power maybe guards could be used with razordons or salamanders in support as guard do have decent staying power.
