Blog NIGHTBRINGER's Terrain & Warhammer Woodworking Projects
Is your stone wall made of tiny rocks? Or is it made of wood that is carved-dremeled to resemble-imitate Stone?
(If I have read this already and forgotten :: apologies.)
Just like the small house terrain piece I built, the wall is made from real rocks (which I collected at the beach). This wall was actually the test piece for the technique I implemented on the house. Behind the stones there is a wooden support structure onto which the rocks were glued.
You got three nice trees out of it. Box it up. Don’t look at it for a week.
Then consult with The Great Pendrake for a new plan. All is not lost.
Don’t throw the rest away. No kidding. I have a plan.
The plan of the Old Ones Revealed
Here it is:
Take the piece and using your band saw or a jigsaw cut it into three pieces. Take care that the warped plastic only exists in the middle piece. The middle piece will be discarded. Next:
Using the tiny stones like the ones from your test wall, build very low (we're talking curbs) walls against the vertical cuts you just made on the two pieces that can hold trees.
Now you have scenic base stands for the three successful trees.
Next:
Build a new pond. Don’t use the water effects this time. Give it a flagstones border perhaps. No embellishments.
Then:
Use the three pieces together as an Oasis.
Here it is:
Next:
Then:
An interesting plan (and a very lovely diagram I might add :)).
I still fear that it would involve more work and effort than simply creating a new one. Plus I've been experimenting with the old piece, a bit more damaged now. :D
I just love how @pendrake gets involved with terrain projects, his help and ideas on my gaming board have been very much appreciated.
Nice wall by the way ;)
Nice
And here are the pictures for my second completed obstacle/wall...
I remember seeing a terrain project in White Dwarf ...that I think was a Beastmen fort... that was made of sticks-twigs in this fashion. I liked that one and have been collecting suitable “timber” ever since.
How tall is yours?
Are these posts made of scavenged twigs or did you carve-sculpt dowels to look like logs?
(I think that is what the WD builders had to do.)
Will you be making wrecked versions of these obstacles? (For swapping out if a chariot, S-tank, or cannon fire takes out a gap?)
A very nice Celtic-style palisade!
Thank you kindly my friend!
And I’m guessing the skull between two of the stakes is from the Chaos Marauders box?
Good eye; you're correct. It's from one of the Marauder standards.
How tall is yours?
The posts are about 2.5 cm tall, and from the bottom of the base to the tip of the posts would be about 3.5cm.
Scavenged twigs. I collected them from the backyard, cut them to size and whittled the tops down to a point.
I hadn't thought of it, but that is a neat idea. For now I want to move onto desert terrain for my TK, but I might one day come back and do something like that.
Font forget to add some of the mixing balls (like the ones yyou find in ball bearings) sell for that purpose... ;):artist:
