Blog NIGHTBRINGER's Terrain & Warhammer Woodworking Projects
Can you show a picture of the plastic material before you attach it to the board?
Yup...
And is that a pressed particle board? From the pic, it doesn't look like plywood to me. Huh.
It is plywood (with a vaneer finish), here is the leftover from which I cut out the test piece...
I painted over the edges, which is why it might look different in my original picture.
Also, did you paint it and if so, what paints did you use?
I did paint it. I used "Craft Smart" acrylic paint that I picked up a Micheal's (a craft store near my house). I used the following colours:
  • Golden Brown
  • Mustard Yellow
  • Expresso (I thinned this down until it was a wash)
  • Dark Yellow
  • Ivory
Each bottle costs just over $1 CAD and has a volume of 59ml. I love this paint for terrain building because I most definitely don't want to waste my expensive hobby paints.
I think that the board you attached it to could use a bit more sanding for a smoother incline, but if you are going to go that far, then you could also us a thicker board if you wanted to in order to make more of a "hill" or "dune" effect. Great work! I really like this project! Simple with great effect and good use in game.
That is a great idea. This was just a test piece, it isn't meant to be terrain at all. I just wanted to see what effect I could achieve without wasting too many materials. I also wanted a a chance to give my new yellow paints a try. I think your hill/dune idea would look really good.
Thanks for the comments!
@NIGHTBRINGER I have used that material (the pattern is called "Cracked Ice") to make frozen ponds. I can confirm it does an OUTSTANDING job when used to make frosty terrain.
Would I be hijacking your thread if I went and dug up pix and posted them in this thread?
Thank you!
Feel free to post your picture. I'd love to see what it looks like using a different colour scheme.
It's not fully accurate because the raised areas are the lighter thin lines you see and the sunken in areas are the darker sections (I think it would work better if it was the opposite)
I really like the desert piece, this was definately the first thing I noticed about it though :confused:, how hard would it be to reverse the colors? Also that is a pretty impressive workspace!
Here is one:
View attachment 35719 ...with some Chaos Warriors on the far bank.
Here is the same pond, but viewed from straight above.
That frozen pond looks amazing too :wideyed:
Do you mean reversing the colours so that the dark colours are painted on the raised areas and the lighter yellows are painted into the recesses? It shouldn't be too difficult, it might look pretty good. I'm so used to painting the lightest colours on the raised areas, but it is definitely an interesting prospect.
Thank you very much. That is my new workshop. We recently renovated our basement and created this little workspace for my woodworking projects. It's the first time I've had my very own dedicated workshop and I love it!
Thank you for your comments/insights!
That's some great stuff!
I JUST got something in called Distressed Crackle Paint that I'm going to try out. There will be a process cutting the top out of a base (square in my case ;)) and gluing some sort of cover to the base, paint the inside a blue color, then filling it with epoxy. I'll probably put something like a head in the epoxy or an arm sticking out of the top, etc. Once that dries, I'll apply the Distressed Crackle Paint to the top. It should give a close impression of an army moving over a frozen lake / tundra. I hope it works, anyway.
By the way, I'd love to see pictures of your workshop set-up! I just moved to a new house about 4 months ago and we are still trying to plan where everything will settle and what spaces we'll want to develop. I also have a band saw, lathe and several other large tools (as well as an aging father-in-law who has a wood-working shop. He designs and builds automata. He designed and made this rocking horse for my kids.
) I could use some good "shop" inspiration.
@Ritual has used that crackle paint, no doubt when he notices this he will pop in.
That crackle stuff is pretty rad. Just make sure your edges are thick enough. Also PVA over it a few times to secure it once it is dry otherwise it's at very high risk of coming off.
Don't rely on it to stick if you want to attach anything to the top of it either - as it'll likely come off very easily. Stick stuff down and crack around it, or be prepared to superglue that stuff back in place!
Here is a little project I finished, it's a glue stand. I saw the idea on the YouTube channel "The Terrain Tutor". Simply put, it is a stand that allows you to keep your glue bottles inverted so that all the glue settles at the nozzle and is ready to use.
I find that as super glue gets older and thickens it takes forever to flow from the bottom of the bottle to the nozzle (I admit that I am not a patient Slann!). It works well with other types of glue as well, so I made slots for my plastic glue and my PVA glue. Although it only saves a bit of time per use, over the long run it is very helpful.
As it is not meant to be pretty, I just roughed it together with whatever scrap materials I had at hand.
She may be ugly, but she gets the job done. I even made a little tray on the bottom, in case I absentmindedly forget to close the nozzle on the PVA glue (I wouldn't want to get the glue all over the table).
Now I am ready to assemble some models and terrain! :)
That is SOOO awesome! I'd LOVE to have a space like that, indoors, where I could simply walk in and start using my tools! As of right now, I have to pull everything out of my shed and set up on my carport. That takes a lot of dedicated time!
So I see a Drill Press, Scroll Saw, Dual Orbital/Belt Sander and a Dremel all set up and ready to go! Yep! Hog heaven!
Btw, I think that glue box is a great idea. I had a similar set up when I was getting my Architecture degree back in the day. Mine was a lot longer since it spanned the length of my drafting desk and was a bit more evevated so that I could work on my models and drawings without impeding my work area. There were spots for my guess, like you have, hot glue gun with catch plate, and I even attached a small, collapsible wine rack to hold simple plastic cups, which in turn, held my multitude of pencils, pens, cutting blades, etc. I had 4 studio lamps (two attached to the back of the elevated platform to provide overhead illumination as well as one on either side of my desk. There were never any shadows on my model! Lol! I need to do that again...
View attachment 35831 View attachment 35832 View attachment 35833
So glad someone else has thought of this... I might copy this glue holder idea eventually :artist:. The other issue I have is the super glue constantly stuffs up the nozzel... :banghead:
Amazing workspace!
Having to set everything up each and every time can really kill motivation. I definitely feel your pain on that one. It also means that you have to have a significant chunk of time available in order to make it worth your while. In contrast, I can just walk in and work on something for 15 minutes if I am so inclined.
Hopefully you can get a dedicated work space set up in the not too distant future. It sounds like you would really make great use of it!
That sounds awesome, such an amazing set up!
You should definitely make one for yourself. I used it yesterday when putting together some old metal minis and it already proved itself to be a huge time saver! The Terrain Tutor from whom I got the idea, constructed his from Lego. So there are many options available in its construction. I just found the wooden route to be the easiest for me.
@Chicken Lips & @Warden : thanks for the comments guys! :)
I'm really jealous... as I don't have a dedicated place even for painting I usually have to arrange things in my office before I can start... And but them back when I'm done... so I don't do much if I don't have at least one hour to spend...
And when it comes to terrain it's even worse... I usually have to do bigger stuff in the living room... so that's only possible if my wife's ok with it (or not there)...
Luck for me i'm like @NIGHTBRINGER I have a man loft just for models :)
