Yup...Can you show a picture of the plastic material before you attach it to the board?
It is plywood (with a vaneer finish), here is the leftover from which I cut out the test piece...And is that a pressed particle board? From the pic, it doesn't look like plywood to me. Huh.
I painted over the edges, which is why it might look different in my original picture.
I did paint it. I used "Craft Smart" acrylic paint that I picked up a Micheal's (a craft store near my house). I used the following colours:Also, did you paint it and if so, what paints did you use?
- Golden Brown
- Mustard Yellow
- Expresso (I thinned this down until it was a wash)
- Dark Yellow
- Ivory
Each bottle costs just over $1 CAD and has a volume of 59ml. I love this paint for terrain building because I most definitely don't want to waste my expensive hobby paints.
That is a great idea. This was just a test piece, it isn't meant to be terrain at all. I just wanted to see what effect I could achieve without wasting too many materials. I also wanted a a chance to give my new yellow paints a try. I think your hill/dune idea would look really good.I think that the board you attached it to could use a bit more sanding for a smoother incline, but if you are going to go that far, then you could also us a thicker board if you wanted to in order to make more of a "hill" or "dune" effect. Great work! I really like this project! Simple with great effect and good use in game.
Thanks for the comments!
Thank you!@NIGHTBRINGER I have used that material (the pattern is called "Cracked Ice") to make frozen ponds. I can confirm it does an OUTSTANDING job when used to make frosty terrain.
Would I be hijacking your thread if I went and dug up pix and posted them in this thread?
Feel free to post your picture. I'd love to see what it looks like using a different colour scheme.
