Crowsfoot
Guardian of Paints
Ok this is very easy to do and take's about 30 minutes.
Step 1 grab a normal skink
Step 2: Remove the crest and hand weapon and cut the tail off, be careful here and watch your fingers,
Step 3: Roll some green stuff you don't need alot about a 5mm ball is plenty, roll 2 small balls for the eyes about 1mm.
Place these over the eyes, use a cocktail stick or a rubber shaper.
Roll a ball about 3mm and then roll out a sausage shape about 10mm in length, then dampen your finger (don't lick your finger as green stuff could be harmful) and push it into a curl but leave around 4mm straight, make sure it's a little bit thinner than the cut tail so when you push it on it thickens to the same thickness, with the remaining green stuff flat it out and put it over where the crest was and smooth down, try and make it look like a cloth.
Job done....
Job done....
