KoW So guys, why should I play Kow?
Nah but just the idea of themed basing has really inspired me, Going to build armies for both games ;)
I'll still call that a step in the right direction! :joyful::joyful:
Exactly what I'm going to do 8th and 9th are to complex for Archie but KOW and AOS are perfect
Is KoW so much more simplistic than 8th or 9th Age?
Yes, it is, or to use less negative terms a lot more streamlined, elegant, and practical, which for me is its big advantage over them as a game. A lot of 8th editions problems came from being a lot more complicated than it needed to be, which was one of the factors which slowed the game down so much, while also making it unnecessarily hard to keep the rules straight, and very often interfering with the game balance. Put simply, it had far too many rules, many of which were either redundant, unbalanced, impractical, badly explained, and in some cases several of the above.
Kings of War, by contrast, has as much complexity as the game needs, and no more, which leads to a much more playable game overall.
Before you decide watch some youtube battle reports that's what I have been doing and the game just seems to flow, destroying units by nerve tests just seems weird at first but it really allows the game to move on, magic items and points are used so more in depth than AOS but no where near as deep as 8th, which is a big plus in my book and THEMED bases horde of 40 models need only be 21, cheap and effective to build an army your 42 saurus warriors are now 2 horde of 40!
Actually Crowsfoot, I reckon it's a great way your engulfing your spawning within the game(s), like you describe. It's quite fascinating how the different mechanics can be a steppingstone for each other, to new and or younger players, there's almost some didactic reasoning behind those thoughts ;)
Perhaps having multiple systems have more than just a handful of advantages. I'm at least getting very optimistic about the development within the fantasy game scene :)
You and me both, I can see us playing AOS and KOW and then as Archie gets older and understands more about the tactical side moving up to 9th or similar, I ordered the rule book and got a very personal message from the seller saying he was thrilled and hoped we would join the forum and tournament scene at some point, which I thought was brilliant customer care.
My big concern with KoW is that I've heard that the magic phase is very limited. The magic phase of 8th edition is one of the things I like most about the game.
No idea yet but it has to be more than AOS due to magic weapons, artifacts, hopefully have the book by Wednesday and were off to the Netherlands for 10 days at the weekend guess what my reading material will be.
The fact is that there isn't a magic phase as such. Spells work as any other shooting weapon. Every spell has a number following it, for example Fire Ball (10) that means that you throw 10 dice. All the spells hit the enemy (or your units in case of Heal, Surge, etc.) on a +4. And that it is, basicly. If you need to wound you roll the hits against the target defence, applying any special rule the spell has.
I admit that that seems like a piece of rubbish, I thought that too. I understand you but the fact is that it works really well. Magic is meant to compliment your army and to give tactical advantage not to dominate the battle field as it did in 8th. I must admit that of all things I really miss the magic mechanics of WFB but you end up looking at the game on a whole and as a whole its just beautifully elegant. Complex in its simplicity if you get what I mean.
My book has arrived and although I've just flicked through atm I'm impressed some nice art work and fluff.
The current core spells are :
Ligthning bolt (N), medium/long range targeted attack spell
Fireball(N) : short range area attack spell (usually with lot of dice)
Heal(N) : heal your units
Wind blast(N) : control spell (no damage), move your opponent units, take some finesse to use but can change a game
Surge (N) : move your own (shambling) units during the shooting phase, allow things like charging someone that was outside your charge arc at the start of the turn, very powerful when used well
Bene chant(N) : offensive buff spell, give or increase Crushing Strenght and Piercing on the target for the turn
Each spell has a level (the "N" above) that is the number of dice that you throw, and means that not all wizard using the same spell are the same.
An elven wizard with Lightning Bolt(5) (and the elite rule to reroll 1s to hit) is and feel more powerful than a human wizard with lighting bolt(3) and without elite.
Not all wizards can buy all the spells, and most have a default spell that they start with and can buy more spells at an additionnal cost. As you cannot cast more than one spell per turn (with one exception once per game with a specific magic item), you usually don't want to have more than 2 spells on any one wizard so save points, so the default spell is often important as another way to differentiate different wizards even when they have access in theory to the same spells.
Note that the Salamander mage priest has fireball(10) and elite by default, making in as powerful as any elven mage at short range, but those elven mages have heal(3) as their default spell, they do have access to fireball(10) but it cost more points (and salamanders mage priest can buy heal(3) too)
The spells might seem simple but they work, they are balanced, and you know what you get when you buy a wizard.
You won't win a game with just one big spell against a complete army, but the appropriate spell at the right moment can and will win you more than a few games.
Its simpler in that there are a lot less oddball rules to remember. The movement phase tactics are easy to learn but hard to master. Giving up flanks and rears is a big deal. Thinking 2-3 turns ahead is what will win you games. Also the added dimension of freindly units being able to move through one another but not charge through one another is really cool. The tactics are just as deep if not deeper than 8th ed IMO. The movement phase reminds me of 7th ed (my favorite warhammer ruleset).
The funny thing is that I hated 7th edition, where the game was often lost during the deployment or even the army list creation (My first game was with my Tomb kings against an untouchable wood elve army, I didn't kill even one of his units), while I like 8th edition and its more balanced starting point, but I love Kings of War.
For me, KoW feels like a redo of 7th edition, not unlike a spiritual cousin of 8th edition, that would have tried to solve the same problems, but with a different philosophy.
For exemple on the problem of IGOUGO, Warhammer added more things for your opponent to do during your turn.so he didn't get bored while waiting for his own turn, while KoW simply made the turns fast enough that you didn't have time to get bored, provided of course that you at least take the time to think about your own next turn and that your opponent is not that guiy(tm) who takes 30 minutes to chose a target for his catapult turn 1.
That is why in tournaments you use a chess clock, solves the slow player problem.
Myself, I think the best thing about the KoW rules in managing the problems of a strict turn based system is that it sets very good limits on how much a unit can do before the opponent gets to react.
Part of this is that the movement rules have good limits on excessive manouvering, with only one pivot and none during an 'at the double' move. Nimble units, including flyers, gain some extra freedom through their extra pivot, but they retain important restrictions on how much they can get away with. Additionally, spells count as shooting, and even nimble units aren't able to shoot during an 'at the double' move. A flying unit can go 20" ignoring obstacles, but it doesn't get to do anything else in the same turn.
However, it's equally important that these units aren't getting any extra actions during your opponent's turn. If I move my flyers their whole movement allowance of 20", I have to take into consideration that if I leave them vulnerable to attack, they're vulnerable to attack. I don't get what was in effect a free extra move if they get charged, which took place before my opponent got to move any units in response.
Similarly, units can't get round the limits on actions through excessive pursuit moves, or gaining extra combat reforms during their opponent's turn.
Quite simply, I get to move so far, and attack in melee or shooting once, and then my opponent gets to react, and the lack of ways to avoid that reaction go a long way to limiting the problems with a strictly turn based game structure.
AAAAAAAARRRGGGGHHHH!
I stop following this one thread and it turns out to be really popular. That is exactly how my luck has been for the last... Um.... a while.
Kow is pretty good - I played a game against my brother and I narrowly won. It really is just as good as 8th age - maybe even better.
Definitely better than Aos, though I will still play it.
The KoW section it's been growing fast. Keep playing and contributing if you can!
I agree with you, actually think that KoW it's much better than 8th, I would say it's up there with 6th.
The more we say about the game the more will follow, I've spent 4hrs tonight making multibases rdy for my armies.
Soon be posting KOW models in my blog....
