Blog Salamander Custom Mini - Xlanax_lot's Workshop
but I doubt it will be a success on my first try...
@Caprasauridae Yeha :S at least for me its been dificult! I havent gotten it right yet, and I Have allready tried it a couple of times....The big problemes for me are puting the right amount of the highlighting paint in the point ( I ussually put too much and never get to the blending part), keeping the colors wet on the brush and as @Crowsfoot mention the white gets to chalky when you dilute it to that level
@Crowsfoot yes he is using a wet palet.
I am corious to see what you guys achieve with this techniques and to hear your tips and recomendations after using it!
I've watched it again and I think if you used citadel edge paints as your corresponding highlight colour it might give better results than using white. I no he is only using white as he is painting skin.
Very nice work. How do you create such beautifully smooth shading transitions (which is especially evident in that last picture)?
Thanks for the video, I'll definitely give it a go. You've definitely mastered the technique. Your painting is consistently fantastic!
The effect is certainly already stunning! When you use the loaded brush technique, do you always go from light to dark (i.e. load the brush with darker colour and add lighter colour to the tip?) or can you also go dark to light? Also, what kind of dilutions you use?
Can't wait to see the final product!
Will have to take some time to watch this video... Great skink priest! Looks. Awesome!
Thank a lot again guys! Always happy to hear it, and if you have any tips or suggestions they are always welcomed!
@NIGHTBRINGER @Caprasauridae @tom ndege
The video and the chanel are definately worth the time! They have a lot of great tips! Looking forward to seeing you try them.
@Caprasauridae I havent been able to do the loaded technique properly so what I have been doing so far is going from the darker tones to the lighter tones and only at the end I have started trying to use the loded brush technique to put the pure white highlight. Its really hard for me hahah :s
I am not sure if you can ho the other way, but I would imagine you could.... At the monent I am only using water to thin my paints
I think the whole idea of the loaded brush technique is to do highlights and not shading.
Base the model in your darkest colour and work backwards to your highlight colour, so your not doing the general method of base, shade, highlight.
That's who I see it working could be wrong, I've ordered a wet palette and can't wait to try it out.
@Xlanax_lot
Do you use a wet palette?
and the skink priest is very nicely done so far.
That is also how I ubderstand it! @Crowsfoot the whole point is to do a fast blending without having to go trough the usuak steps! i havent been able to get the correct mix in my brush so I end up having a lot of white, that is why have bern doing a mix between the loded brush and the "traditional" technique.
Yes, i am using a wet pallet, they are awesome!
Mine arrived today so hopefully get it used soon
The white marble looks good, but definitely needs some black veins on it. That's what, at least to me, makes the marble.
I thought the same, just some small broken black lines will finish that off, how did you achieve the effect?
It looks fantastic ;)
