@NIGHTBRINGER I ussually put a little bit of soap on the mold and thats it. It has worked great for me, but if you are habing trouble, make sure you do this two thibgs:
1. Ensure that the green stuff is well attached to the base before u use the mold on it ( make sure there is no water or any liquid between the base and the green stuff)
2. Put a couple of drops of soap in the mold and start by releasing all the corners first ( diping it ina little watter with ice also helps in removing the mold)
Hope this helps!![]()
So does this pertain to making the mold or using it? I've made the mold, now I'm looking at casting my plastic model. I'm wondering if soap will be sufficient to ensure that my newly cast plastic can be removed from my green stuff mold.
