Killer Angel
Prophet of the Stars
EDIT: Asked other players. They confirm that you can dispel an ES and cast it again in the same turn.
You need a citation of a FAQ or something similar.
The core rule is that you cannot attempt to cast the same spell more than once in the same turn (even with a different wizard).
To bypass this rule with endless spells, you need a rule that specifies that endless spell don't fall under that limitation, otherwise you cannot.
