Chameleon Skink
olderplayer
Glitch in system, Double post.
hdctambien said:JuQ said:Right now that the enemy ccan choose wether to attack the skinks or the krox, what is the niche of this unit? what is it good for?
If you face weak troops they can just obliterate your skinks with S3 and WS3 attacks while your kroxs attacks doesnt really worth that much. If you engage more elite unit they will probably kill your kroxs almost as if they were skinks.
Their niche is as a tarpit with a bit of a bite that can get the charge and want to target things that don't have a lot of static CR.
A unit of 3 Krox and 24 Skinks with Standard and Musician matches up almost evenly against a Doombull with Sword of Swift Slaying, Dawnstone, and Ramhorn Helm (I don't know if this is the optimal build of a Doombull, this is how the guy I recently played ran him)
By my math, if the Bull puts all his attacks into the Krox the CR ends up being 5.27 to 5.14 in the Bulls favor (barely) and the Skrox have a musician to win the tie.
If you compare 2 Krox and 16 Skinks to this Doombull the final CR is Bull: 4.9 to Skrox: 4.55 which is similarly close and saves you 90 points in case the dice don't go your way.
Those numbers assume no charge bonus (or impact hits from the Bull). Whoever gets the charge should win the first round of combat. And that is where the Krox ultimately beat out any unit of Saurus. Movement 6 can get the charge they want more often than movement 4.
This is also assuming the Beastman player always attacks the Krox. If he decides to put some of this attacks into the skinks then he is going to start losing combat by more and more.
Pinktaco said:S6 stegs.
S5 templeguard, with AP banner they're effectively just as good as stegs, just more attacks.
S7 cowboys.
S7 regular kroxigors (units of 8).
Pinktaco said:The only reason I see us fielding skrox units is if we want to have fast (M6) moving Core units who can flank whatever is hitting our templeguard unit, but in the end I still think I'd rather just pick up 30 saurus with spears.
