TOW Square Based Renegade Lizardmen Changes Mega Thread
Gothmog Lord of Balrogs
238
135
43
So Val of Square Bases has Released his "Renegades Pack"
To use his words on what the Renegades Pack is"
"What this is definitely not is a full re-write of these factions, or even an attempt to balance
them really. This is a mostly straightforward edit of the army lists to remove unnecessary
restrictions and free up the generally good rules that already exist for the Renegade factions.
If we’re to accept that the Legacy PDF Lists will be what we’ve got for a while, then I think
they need to be opened up to allow more freedom in the types and styles of armies that
players can create."
I don't think its up for debate that Lizardmen are in a rough spot for TOW and need help. This post isn't really to discuss that, or the merits vs drawbacks of a community edit/comp of the legacy PDFs.
What I'd like to discuss here is if we think these are the right fixes for our lizards, if its too much or not enough, going in the right direction etc. etc. What about the below do you like or dislike. If the Legacy PDF was this below, how do you think Lizards would be faring.
With that, here are the changes.
Link to the Renegades Pack
Renegade Core Rules Changes
When using the Renegade Army Lists the following core rules are added:
Howdah:
(Rulebook P. 171)
● Add: In combat, all enemy rolls To Hit are made against the Weapon Skill of the
Behemoth, instead of the Crew. If this model is also a character’s mount, follow the
rules for Split Profile (Chariot Mount) (Rulebook p. 205) instead.
Lizardmen Renegade Army List
Characters
Up to 50% of your army’s points value may be spent on:
● 0-1 Slann Mage-Priest per 1,500 points
● 0-1 Saurus Oldblood per 1,000 points
● Saurus Scar-Veterans, Skink Priests and Skink Chiefs
Core
At least 25% of your army’s points valuemust be spent on:
● Saurus Warriors
● Skink Skirmishers and Jungle Swarms
● 0-1 unit of Temple Guard (if your General is a Slann Mage-Priest.)
Special
● Chameleon Skinks, Kroxigor, Temple Guard, and Cold One Riders
● Terradon Riders and Ripperdactlyl riders
● Bastiladons
● Stegadon
Rare
Up to 25% of your army’s points value may be spent on:
● Salamander Pack
● Razordon Pack
● Troglodon
● Ancient Stegadon
Mercenaries
Up to 20% of your army’s points value may be spent on mercenaries.
Allies
Up to 25% of your army’s points value may be spent on a single allied contingent drawn from the following Grand Army composition list:
● High Elf Realms
Battle Standard Bearer
A single Slann Mage-Priest, Saurus Scar-Veteran or Skink Chief in your army may be upgraded to be your Battle Standard Bearer for +25 points. In addition to their usual allowance of points to spend on magic items, a Battle Standard Bearer can purchase a single magic standard with no points limit. A Slann Mage-Priest may be both your army’s Battle Standard Bearer and its General.
Lizardmen Renegade Rules Changes:
Cold Blooded
(Lizardmen Army List p. 20)
● Replace with the following text “When required to make a Leadership or Break Test,
models with this special rule may roll an extra D6 and discard the highest result.”
Slaan Mage-Priests
(Lizardmen Army List p. 3)
● Movement: Change “4”
● Troop Type: Change “Monstrous Infantry”
● Base Size: Change “50 x 50 mm min, 60x60 mm max”
● Special Rules: Delete “Large Target”
● Special Rules: Add:
○ “Wisdom of the Old Ones
Once per turn, the Slann Mage-Priest may re-roll one of the D6 when making a Casting Roll. In addition, it knows one more spell (chosen in the usual way) than is normal for their Level of Wizardry.”
○ “Palanquin
This character may join a unit with the Guardians special rule despite having the Fly special rule. As long as the front rank has a minimum of 4 models they may be placed in the second rank. However, they continue to confer benefits to the unit in the form of Leadership and special rules, but may not cast Assailment spells. As long as this model is not in a fighting rank, they may cast and dispel as normal, even if its unit is engaged in Combat. For the purposes of shooting and casting spells, this model has a 360° vision arc and ignores models in the unit for drawing line of sight. In addition this character passes any Look Out Sir rolls it is required to make. If the model with this rule is unable to fit neatly into the unit, count its base size as if it were on the correct base size for all purposes for as long as it remains in the unit. IE: a Mage-Priest (50mm x 50mm) counts as having a base of 60mm x 60mm when it joins a unit of Temple Guard (30mm x 30mm). To achieve this, you may use a spacer, or simply leave room to either side of its base on the movement tray so that rear ranks can close around it
correctly.”
(Lizardmen Army List p. 6)
● Special Rule: Guardians Delete
○ “Should a friendly Slann MagePriest model that is within 3" of this unit suffer a bhit during the Shooting phase, roll a D6. On a roll of 2+, you may choose to transfer that hit and all of its effects onto this unit.”​
● Special Rule: Guardians Add
○ “This unit may be joined by a character with the Palanquin special rule.”
Stegadons
(Lizardmen Army List p. 13)
● Special Rules: Arcane Configuration, Delete
○ “If your army contains two or more Engines of the Gods”
Salamander Hunting Pack
(Lizardmen Army List p. 9)
● Weapon Profile: Fiery breath, Replace “Breath Weapon” with “Column of Fire”
● Weapon Profile: Note Add “If the artillery dice result is a misfire, no shots are fired] and D3 Skink Handlers are removed until there are none remaining. If no Skink Handlers remain when a misfire is rolled, the Salamander losses a wound instead.
I saw this pop up on reddit and honestly its the lightest touch ive seen in "fixing lizardmen", including my own, but its pretty bang on in the immediate issues with the core of the army. Loosing the 1+ SW requirement and slanns being no longer solo is sooo nice, im gonna try playing it locally, atleast for weekly casual games
Yeah. Super light touch.
A few areas I'd like to see it go further and still be "light"
-blowpipes are free
-giant bow gains through & through
-razordons ignore penalties to BS for multiple shots.
-blowpipes are free
Basically this.
If this was done then we'd be roughly back to the 8th rules for things. In that though I think razordons had no more nails. Which would be nice back but I'd take more shorts of any kind with them
-blowpipes are free
Agree although for their points I think salamanders need something else even with column of fire, say for example move & shoot
Question then becomes if it had move & shoot, would it become something you always took? If that's the case, maybe that is a little much. Or it needs more points cost.
I think quick shot though so it can always be used as stand and shoot would be perfect though
a) if it has column of fire and move & shoot it would appear in 0% of tournament lists. At 75 points, for a worse Kroxigor which are 2/3 the price, that do a template attack that is reasonable against infantry (which are terrible) they would be in C tier in social games, potentially B as their skirmish would help. No way would they be too good, they are the worst unit in our army list except perhaps the Slann
b) template shooting attacks cannot stand & shoot.
Yeah it's really light touch, however already to put the slann in TG that test always at 3d6 and avoid saurus infantry (expensive and weak) is already a good step forwards. Like also the Stegadon in the special choice.
Had my first game with this on the weekend. Absolutely added to how fun it was! Having a functional Slann you could rely on not to die before turn 3 was amazing. Too early to rate in terms of power but I can say it will make social games much more enjoyable
I'm really eager to try it
One non-obvious boost is there are quite a few spells that used to be useless that are now great because the Slann can be inside a unit. Deathy cabal went from useless to good. Plague of Rust went from great to slightly better (it can be cast by your Slann onto the unit the TG are engaged in combat with). Earthen Ramparts went from useless to great. And walk between worlds went from good to god-tier (against the right army)
In 2 weeks we will have a team tournament using renegade rules! Using NO saurus and only one ancient stegadon but still getting the +1 to cast would be really interesting! (No slann since i have only 1000 points)
At least you can take a skink priest and an old blood in the same army!
Although very possible to take a Slann at 1000 with a big group of temple guard, true that's 700-800 points worth but it will help you dominate magic
Would anyone like to join in writing an official but of feedback to this update, so it could come from multiple people from this board?
Something like:
1) Troglodon should have swiftstride and move & shoot
2) Razordons ignore penalties to BS for multiple shots (or should they use the artillery dice?)
3) Salamanders gain move & shoot
What is the best way to make blowpipies viable without adjusting points? Skink javelins are already too good, so I don't think we want blowpipes to be "better" just worthwhile taking. Would giving them move & shoot be enough? And would that make cham skinks viable or would they need something else say -1 to hit?
Is there anyway to make Saurus viable when Temple Guard are now just plainly better? Maybe their spears could have -1AP?
I put in some feedback about giving back the troglodon beast rider from 8th (making the trog WS count for everything) and giving back razordons no more nails. Im not sure how id want them to address blowpipes and saurus warriors. I'd like magic banners maybe on warriors and anything to make blowpipes worth, maybe posion on 5s as well ?
Chamelon skinks i think need both move and shoot and -1 to hit for them to work.
Beast Rider means the Troglodon's weapon skill is used when it is being attacked? I was thinking swiftstride and a 4+ save.
What does no more nails do?
Magic banner on Saurus is a good suggestion but I still think no reason to take them over temple guard.
Poison on 5's wouldn't work because what happens if you need a 6+ to hit?
I might come up with a survey or something and give to Val as a "these have unanimous approval, these have 75%+ approval" and we all have to remember the mantra is not to improve our armies power level but to fix totally broken D grade units and get them to C or B tier.
Yeah beast riders would functionally be a -1 to hit the troglodon until WS7 which at that point it's way out its depth anyway. More armour and swithstride would help but also improving it's shooting would also let us have a more skirmishery monster like it look liked in 8th.
No more nails or grape shot(in 8th) is one artillery dice worth of auto hits. Razordons got that with move and shot and quick shot in 8th and could pepper things to death. It wouldn't be bad a worse but highly agile volley gun.
Good shout on chameleons, just give them quick shot innately and they'll be fine so they can maybe hit on 5s sometimes lol
I'm not fond of removing mandatory Saurus Warriors personally, it was no different to other armies having to take 1+ of something, including the supported ones, and with no sign of the required points reduction for Saurus and points hike for Skink Skirmishers, people will just mass more Skink Clouds than ever to fill out their Core slots... maddeningly.
Lizard armies are meant to involve a Saurus core with Skinks in support, not Skinks filling out the entire Core tax, yet since 7th (possibly even 6th) the spineless Skink Cloud tactic has just dominated Lizardmen gameplay. It isn't even a good tactic because your opponent can just take out the Skinks with magical or War Machine shooting or force them into combat where they will be shredded.
They explain the logic being that they remove the 1+ from most legacy factions since this probably the only update they will get so this opens up options. Yeah you can run skink cloud but now we have temple guard doing actually useful things with slanns to bulk up points. Saurus warriors need help, i mulled around what if they got predatory fighter back alongside TG?
