TOW 1750 Tournament List
Kkabba
2
2
Playing in a 1750 tournament in the new year and thinking of using the below list.
We are allowed to switch lores between games so Slann will switch between Battle and Elementalism depending on opponent.
25pts left to spend but not sure where to invest it.
Will be using the list tonight against Beastmen. It will be my first time running the Lizards in Old World too, so no doubt it will be a learning curve.
For tonight’s game I am leaning towards Elementalism at the moment. I know my opponent is bringing 6 dragon ogres (2 units of 3) and chariots so my thinking is that the wind blast will be better than fireball, along with plague of rust to drop armour for skinks.
Kelpie (Kroxigor)
Lizardmen
1,725
Slann Mage-Priest 450
Ruby Ring of Ruin, Lore Familiar, Obsidian Lodestone*, Battle Standard Bearer, Discipline of the Old Ones (Higher State of Mind), Battle Magic
Saurus Oldblood 407
Talisman of Protection, Blade of Revered Tzunki, shield, Carnosaur
10 Saurus Warriors 157
Spawn Leader, Shieldwall
15 Skink Skirmishers 85
Scouts, Lustrian javelins and shields
10 Skink Skirmishers 50
4 Kroxigor 196
Stegadon Ancient 230
How did the game go?!
Did you find my use with the blade on old blood, if you swapped it out for the ogre blade or just a GW and put the points elsewhere do you think that would have made a difference?
Did the Krox’s get up to much and how did you find the Slann?
Keen to hear how you went!
Hey!
Game started off very well for the Lizardmen.
For starters this was my opponents units, as best as I can remember them;
Beastlord on Chariot
Shaman LV2 on Chariot
2 x Tuskgor Chariot
10 Ungor Raiders
3 x Razorgor
2 x 3 Dragon Ogres
Giant Chaos Spawn
Carnosaur took a flank with Stegadon. Kroxigor took centre and Saurus took opposite flank to hold against a building that sat next to the flank. Skinks ran about just nailing shots into viable targets etc
With the help of Plague of Rust the Carnosaur took a unit of dragon ogres in turn 1. They fled and carnosaur chased them and caught them.
Turn 1 the Kroxigor also got repositioned via travel mystical pathways to the same flank to take on the second unit of dragon ogres.
In Turn 2 the Kroxigors, with the help of plague of rust took on the dragon ogres and won. The following turn they finished them off.
Down the opposite side things were looking ok. My opponent had two chariots coming down on the Saurus, but he failed charges with them both. Putting them in prime position to be charged by the Saurus in my following turn. No doubt the Saurus would have won the combat.
Unfortunately things started to go south turn 3 onwards.
The Carnosaur was stuck on the flank chasing chaff. After he had caught the Dragon Ogres he failed LD to reform. Meaning he couldn’t turn to face into my opponents general (beastlord on chariot). Had he been able to I would have been able to take out his general by turn 2/3. But my opponent fed him chaff turns 2 & 3.
The Saurus got blasted by viletide before they could charge. Blasted by a level 2.. and my Slann failed to stop it!. Viletide killed 8 out of 10 Saurus. Pretty much rendering them useless now.
By turn 3 I had his shaman on chariot surrounded by 25 skink. He had 4 wounds left. I moved my slann into a position to cast plague of rust, ruby ring and wind blast and hopefully with the skinks ensure I killed him. Unfortunately I failed to cast plague of rust and ruby ring. Wind blast took 2 wounds, skink only managed to cause 2 poison, he saved 1. Leaving him with 1 wound left.
Unfortunately in turn 4 this meant his shaman charged my slann to lock him in place. Knowing he couldn’t kill him, he locked him down until his razorgors could get in and defeat me on combat res and unit strength.
The slann eventually did fail this way, fled and was chased down.
By this point we called the game as he had killed my Slann, Stegadon and 3 skink units. I had killed both units of 3 dragon ogres and a unit of 10 unfit raiders. My carnosaur wasn’t going to get back into the fight by the end of the game and it was late.
It was a great first game and I really enjoyed using the lizards.
But to get to your main questions…
Shortly after posting this thread I swapped out the Blade for the Ogre Blade. And it certainly proved its worth. I just think that the D3 Multiple wounds gives you so much more versatility. Take the Dragon Ogres for example. All my attacks managed to hit and wound. Had I had the Blade I would have just done 6 wounds. But because I had the ogres blade I ended up doing 12. Yes I had to use plague of rust to help it, but still, AP-2 is still great. Both blades are good for characters and dragons, but the ogre blade is also great against any monster or multi wound models.
The slann is a tough one. Nothing makes him better than any other caster on the board. He is certainly overcosted. But I feel like he is a necessary expense. Had he not supported the Kroxigor with plague of rust, or moved them into a better position I would not have done so well with them. I feel like the Lizardmen units really need the magic support to get the best out of them. That means the slann is probably going to be a requirement for me.
Kroxigor were great in all honesty. But they were also screened by skink and supported by the slann. I think this is probably necessary. They also NEED to get the charge.
The skinks were star of the match. They didn’t kill much, I really didnt roll many poison shots. But what they did was get my opponent to charge them and put themselves in a bad position so I could counter charge.
I see people mention that they struggle to use the skinks with the skirmish screen. In the game I positioned them midway between Kroxigor and opponent. Let’s say my opponent can get a 12” charge maximum. Then I’m positioning my Kroxigor 13” and positioning my skink about 5/6” away from them. My opponent has to either just walk up to the skink. Or charge them to get up the board. They flee and my opponent has to go the full distance rolled. Ideally the skink have run past the Kroxigor and my opponent has landed in perfect position for me to charge them in my turn.
Awesome man! Great to hear you had fun
I agree the ogre blade just wallops whatever you put infront of it - looks like PoR really popped off but man it must’ve been rough when viletide got off hahah
I’m with you that I think the Slann is necessary evil - not being able to do anything in the magic phase feels like you’ve neutered yourself hahah
Great Battle rep aswell, thanks for the insight!
Some suggestions:
15 scouts are too many, I have already difficult to deploy 10...
Skinks units are optimized to 12 and 16, remember that! Due the panic ;)
25 points can be more skinks, an engine of gods or an extra lodestone to the slann (or a dispel scroll) =)
