Ripperdactyl
Kalisto
Interesting but probability against dragons are still low. I mean 5 attacks hitting on 4+ in best case, maybe 5+ then you need a 6. And you don't negate ward saves...In exploring my rules question above, I found another Oldblood build that competes with the 2 big ones. And actually, I think it's probably better.
Because the Sword of Might is an extremely common magic item, you can take it along with the Dragon Slaying Sword. Then you can use the sword of might against non-monsters. This is relevant because most of the non-monsters are T4 with some amount of armor. The result is the first unit in my spreadsheet that wins every battle I simulated, although not always by large margins...
- 27.366 - Saurus Oldblood on Carnosaur - Dragon Slaying Sword, Sword of Might, Shield, Talisman of Protection
Even though the efficiency score is slightly less than the ogre blade, that is mostly because the ogre blade adds a lot of extra wounds against monstrous infantry and cavalry. This build is still fine against those, it just doesn't win by as large a margin. But it is WAY better against dragons and monsters, which are much bigger threats. So, my opinion is that this build is better.
Also yes, this build does score significantly better than either the DSS or the Sword of Might by themselves...at least according to my spreadsheet.
Then I'll probably prefer Revered Tzunki Blade that is more allround effectively against everything and negate both armour and ward saves (even without 6s). Ogre blade is strong but useless against dragons with good armour+saves.
The first is luck based, the second on strategy. Probably you cannot kill a dragon alone but you can kill a dragon with some support as a stegadon charging. The first option barely is ok against heavy cavalry. The second option slay them. Probably both option have to ben tried =)
About other monsters...carno eat them, so the problem are dragons with T6 and ward saves.
