SkinkPriest37
I am trying to build a cheap gaming board using foam board and XPS foam. It is likely that I will put an XPS foam sheet on top of the foam board because I plan on carving some stone paths into the foam. I don't have a heat gun or hair dryer. I should also point out that I don't have a glue gun either.
Here's the problem, what glues do I use? Do I need to seal or do anything to the paper parts of the foam board before I glue the XPS foam down?
I am aware that Army Painter does foam safe terrain primer and sealer. It's not cheap and people seem to reccommend water and PVA glue with some paint anyway. I'm trying to keep costs down as much as possible whilst maintaining a nice to play with gaming board.
I'm sorry if this is posted in the wrong place.
