Blog Sleepy corner
Last couple of days were quite dramatic. Whole family now with covid, kiddo went to hospital due to complications (they released him next day), so there was no energy for hobby. Today, I no longer felt like husk when I woke up, so early morning, I snuck up to balcony so I do not inhale glue and put together engine of the gods. Skink crew is currently at office where I'll not have access for some time.
Now at evening, I took out skinks to make at least some progress on them and found out that I don't have any good brushes left at home. I need to get some of my cheap ones to working condition tomorrow.
This is great work mate. Nice one!
Thanks a lot, I hope nobody checks them closer as there are plenty of overdraws :D
Also on funny note, I ordered box of skinks couple of days ago and today, while checking order status, I noticed for the first time that I in fact ordered chameleon skinks :D
And some progress on my classic skinks, I am about 70% done, but no pictures taken before I shoved them back to cupboard.
Love the cold ones and the skinks, you have painted them some gorgeous and bright colors!
Thanks a lot, but most of this I own to speedpaints. That great saurus green is achieved by mixing 1:1 zealot yellow : plasmatic bolt and me figuring out was one of those happy accidents actually. :)
As for those skinks, they go way back to third page of blog:
...I have just finished slapping speedpaint on those skinks and paint was just sliding on the surface...My reason told me to stop painting, figure out what is wrong and correct it. Right?... No, I went full panic mode and slapped even thiccer coat of speedpaint onto them, smearing those surfaces even after it was semi-dry. Right now, skinks are blue... But they look worse than my first attempt with contrasts couple of years ago. Splatches and pooling everywhere.
Maybe that overexposure of light helped to hide some bad spots, but they are not great :D
When I order box of skinks (correct ones this time), I need to properly degrease them prior to painting.
Next move is decided. One unit of guards, 2 salamanders (without handlers right now), DIY ark of sotek and EOTG.
I need to do basing on guards (milliput stone carvings are drying right now) and degrease all. With some luck, I should be able to prime them tomorrow evening.
Allright, all primed and as bonus I added starpriest from SC:Skinks I already had prepared and forgot to include in last update.
I found out that my primer changed color in between batches and that is why it seemed darker last time I used it and had to buy white spray to lighten it.
I used what was left in old spray to prime big dinos on first photo and newer spray to prime platforms and bases, so difference is clearly visible. Then second priming session of guards and starpriest was done with newer (darker) primer and then white zenithal. There will be some painting soon :)
I can now return to painting :)
Small progress at least. Bases for EOTG, Ark and salamanders are mostly done. I used my normal method of choosing color scheme (decide on number of paints and then grab them randomly) and started with Ark, as it is one of my oldest WIPs here.
Allrighty... Crew and snakes are at the office. Darn, time to start on other ones. OPR spiked lizards (to be used as salamanders). I had to get them printed at 75% scale to fit bases and those details became really small. Also one of them had some imperfections, so I decided to rough him up a little.
Today is just small update. Nothing significant. I varnished salamanders to keep speedpaints from reactivating during cleanup and found old EM4 orc primed white, so I decided to use him as guinea pig for spray varnish that I want to use for all my seraphon. It is from same company as my primer, so it should be fine, but I rather test it first than ruin all the minis I painted in last 3 months :)
If it works fine, I can finally start putting some tufts and grass on bases.
Thanks guys. This was the first time I tried dark grey speedpaint on silver base. I am really pleased with that result.
How do you like the speed paints thus far? I'm wary because they are reputedly liquid resin based?
