C Skink Chardling New Member Messages 18 Likes Received 2 Trophy Points 3 Oct 12, 2021 #1 Hi All so I’m pretty new to Aos and just need to clarify, do abilities such as serpent staff use a CP? I’m assuming that if the ability description doesn’t specify Command Ability then it doesn’t use CP?
Ripperdactyl MackiMac Well-Known Member Messages 415 Likes Received 1,139 Trophy Points 93 Oct 20, 2021 #2 Command abilities are the only thing that cost command points
Skink t4tcliff Member Messages 48 Likes Received 32 Trophy Points 18 Oct 20, 2021 #3 Chardling said: Hi All so I’m pretty new to Aos and just need to clarify, do abilities such as serpent staff use a CP? I’m assuming that if the ability description doesn’t specify Command Ability then it doesn’t use CP? Click to expand... Nope, if it requires a command point being spent it will definitely say COMMAND ABILITY. Serpent staff is just a warscroll ability and can be used for free during your hero phase as long as the target unit is within range.
Slann Killer Angel Prophet of the Stars Messages 20,909 Likes Received 42,315 Trophy Points 113 Oct 20, 2021 #4 I will also add that, being an ability, it doesn't suffer from the additional restrictions of C.A. Thus, with 2 starpriests, you could use it twice.
C Skink Chardling New Member Messages 18 Likes Received 2 Trophy Points 3 Oct 20, 2021 #5 Thanks for these replies guys!
