Gotta remind you that a Celestial Tome is not a Battletome. This is beta before our update at some point in the delayed future.
What's Thunderquake about?
Thunderquake is a battalion made of 1 Skink Chief Stegadon/Engine of the Gods, 2 Stegadon/Bastiladon, and either a kroxigor or razordon/salamander.
You get the choice between Swift or Slayers. Swift is either a once per battle free At the Double or Forward to Victory, Slayers is the same for All out Attack or Unleash Hell. This is only for the units in Thunderquake, but since it doesn’t count as issuing a command to use the abilities it’s got some synergy use to it
Our grand strategies are:
Continous Expansion (Coalesced only)
When the battle ends, you complete this objective if you have one friendly unit wholly within each large quarter of the battlefield.
The Astromatrix (Starborne only)
An imaginary Ley Line 1mm wide runs between each corner of the battlefield to the diagonally opposite corner of the battlefield. When the battle ends you complete this objective if a lay line does not pass over any enemy wizard, and at least one lay line passes over a friendly wizard.
Battle tactics are:
Might of the Starborne (Not starborne only, weirdly)
Pick 1 objective on the battlefield. You complete this battle tactic if you summon a friendly unit worth at least 20 CCP during the turn, and wholly within 12” of the objective you picked.
Stampede of scales (also available to both)
Pick 3 different friendly Monsters. You complete this battle tactic if all the units you picked run in the following movement phase and finish that run in 6” of one another and wholly within enemy territory.
