I hope you have had the time to sit down and reflect on your lives choices
2, you wear a tie at the bottom of your neck, not right under your chin.
The WETA crew did a lot of practical special effects for the movies, as becomes readily apparent at Hobbiton. Whenever a scene involving a hobbit near their hobbit hole is featured, the relevant hobbit hole is scaled up in size to make the actors look hobbit-sized, whereas the remainder that show up in the background vary in size from actual hobbit size to even smaller for an illusion of depth.
