Christopher
The subject line says it all, I'm going to be pitting my Seraphon army against the Ossiarch Bonereapers soon (so I'm super glad to see @Killer Angel's new battle report!) at 2,000 points.
So I've been theorycrafting, reading their Battletome and errata, etc.
One thing I'm considering doing is using the Geminids of Uhl-Gysh (if the Malign Sorcery box I ordered ever actually shows up) in a Slann-led Starborne army with Lord Kroak, a Starpriest and two Priests (and Knights and a behemoth or two). So, lots of spells and spell-like effects.
However, the best thing about the Geminids of Uhl-Gysh is that they can prevent units from issuing or receiving commands (note the language of the warscroll does not use "command points," just "commands").
The Ossiarch Bonereapers don't use command points, depending instead upon their Relentless Discipline points. Now, the (very friendly, actually) guy I'm playing has already played a couple of 3.0 games and successfully convinced his opponent that the Geminids, while they still do a mortal wound, do not prevent his units from issuing and receiving commands. I don't think that's right, because in their just-issued errata, under the header Using Relentless Discipline points, it says this:
So I'm making a distinction between the verb (command) and the noun (command points) that might seem to some pedantic, but I really do think the Geminds are meant to work against the Ossiarch Bonereapers.
Thoughts?
Relentless Discipline points are used to issue a command (emphasis mine) in the same manner as command points...
Thoughts?
