Killer Angel
Prophet of the Stars
Nah.
But of course, if someone is able to write about CD with my theme...
Thank you kind sir.A magnificent K’daai Fireborn @NIGHTBRINGER, though your painted models are rare, it’s always worth it to see a new one done!![]()
Now you just need to paint the other two (or more, depending on how many the Mrs got you)...![]()
I get that too. Sometimes it’s hard to push past it but if you keep going it usually turns out in the end. Most of the timeI call that the "Oh No Phase", I have it for almost every model at some point.
Good job!
I get that too. Sometimes it’s hard to push past it but if you keep going it usually turns out in the end. Most of the time![]()
Her 14th post... and it only took her 6+ years!+1
The lady speaks sooth!![]()
It begins!
Resin has been cleaned, bits have been cut from their sprues and mold lines have all (hopefully) been removed!
It is indeed!Nice! Looks like a Magma Cannon?
It is indeed!![]()
Some more assembly, undercoat and a basecoat of metal. I also applied a thick black wash on the underside of the platform and to the components below it (prior to adding the platform because it will be hard to get a brush in there with the platform added).
The assembly of this model has been an absolute nightmare, with things not lining up properly. Not sure if something is warped or if the sculpt is problematic or if I messed something up along the way. Too many things need to line up and if any one thing that is slightly off, it throws everything else off. Definitely not up to the standards of GW's current plastic models in terms of ease of assembly (plus I've never been particularly great at assembling things).
Worst model I've ever had to deal with in terms of assembly, and that includes this notoriously difficult model I struggled with in the past:
It's Forge World. So it's in resin as opposed to GW hard plastic.This looks like a nightmare...
Is it a FW or GW model?
Still working on my Magma Cannon, but in the meantime, I assembled, green-stuffed (outside of two small air bubbles that still need to be attended to) and based this big beastie (Chaos Warrior is there to provide a sense of scale)...
View attachment 95983 View attachment 95984
