Skaven Slave
Lizards of Renown
Clan Rictus
Thank you! View attachment 83482
I like the custom Chaos Dwarf smiley... The fact that he has a "top hat" is not lost on me.
Xmas woodworking. It takes away the best of us... it's the price we have to pay, waiting for a brighter tomorrow.
But surely, the time has come to finish the battle royale?
And he has been aesthetically prolific!
All kudos to him, his work pieces and his workshop which I'm fairly jealous about
I've been painting!!
Planning something cool for tomorrow, details to follow.
Hahaha... that's fair!Blimey! What brought that on? Something you ate at Christmas?![]()
I've been working on my prototype Chaos Dwarf colour scheme. He is almost finished.I look forward to seeing what it is that you’ve been so desperate to paint!![]()
I've actually painted a couple of small things (and started a bunch of things), but I've yet to take pictures of it.
But for tomorrow's event I'll be painting something completely different and new. @Mrs. NIGHTBRINGER is joining in too!
And they say Hitchcock is the master of suspense...![]()
Patience my young Padawan.New Year's Day has come and gone my friend...
FIGHT! FIGHT! FIGHT! FIGHT!![]()
It's going to be a little while longer. I'm about to go on my Octuple Slann mini hiatus!
the Demigryph and Hammerer matchup is declared a draw. Each of the two results is just as viable as the other. I can think of nothing fairer than treating their 1-1 record as a draw.
Hey, don’t blame us Dwarfs, blame the Demigryphs for having shit riders, you just can’t trust an Umgi (particularly an Imperial Umgi) to get a job done
- I hate those damn Hammerers in this competition. Whenever there is a problem (outside of errors on my part) those bastards are usually a part of it (i.e. their White Lion matchup was razor close too).
- the Demigryph and Hammerer matchup is declared a draw. Each of the two results is just as viable as the other. I can think of nothing fairer than treating their 1-1 record as a draw.
Well, well, well... it's well past time we got back into the swing of things ( @Lizards of Renown ). To start things off, we need to face the problem that I ran into before my hiatus from this thread... namely, the Hammerers vs. Demigryph Knight matchup. I shall present you with the problem, my proposed solution and then ask that you each weigh in on my solution. If you have an alternate solution that you deem to be more fair, please put it forward and we can all discuss it before we collectively deciding how to proceed.
So let me take you on a little adventure filled with the annoying need to re-calculate previous matchups.
It all started with the following Demigryph vs. Hammerers matchup (the headers are misaligned because I shrunk down the size to fit it into single picture screen grabs, so as to not hit the 10 image forum post limit... I shall return to normal size after we resolve this)...
It seemed like a simple enough victory for the Hammerers, but I found it strange that the Demigryphs lost this matchup, while their Monstrous Cavalry brethren, the Mournfang, won this very same contest. So I took a quick look back and noticed that the Mournfang vs. Hammerers matchup was contested at lower points total (360pts per side). These situations are bound to come up as I've typically aimed for contests pointed at somewhere around 350-425 points (give or take, monsters excepted), depending on how I can best even out the points between sides. However, having one side win (Mournfang) and another side lose (Demigryphs) based potentially on a random starting points cost (where both sit inside the typical values used throughout the contest) seemed wrong. So that required some further (painstaking) investigations. And we have...
And therein lies the problem. By shifting the points total by the margin of a single Demigryph Knight, the results are flipped!!! At a 416pts start, the Hammerers win, but at the 358/360pts start, the Demigryphs win. Both point totals fall within the typical values used for the tournament, so both results feel equally legitimate.
Of course, this all meant that I had to go back and apply the same starting conditions to the Mournfang and the Skullcrushers in their matchup against the Hammerers.
The Skullcrushers, as I suspected, win in both scenarios...
So no issue with the Skullcrushers' result, nothing needs to be changed on their front. Then I went back into the Mournfang matchup...
So the Mournfang surprisingly win the contest at both the lower and higher starting points levels. This was admittedly a bit unexpected, as I figured they would follow the same trend as the Demigryph Knights did. It took me a bit of time to realize the obvious difference that was staring me in the face, it came down not to the starting point size, but the starting model count. There is a significant disparity in the points per model between our 3 MC units:
Because of this, the starting model count varies at the lower and higher unit points costs:
- Demigryph Knights = 58pts
- Mournfang = 70pts
- Skullcrushers = 78pts
- Demigryph Knights = [7 models @416pts] and [6 models @358pts]
- Mournfang = [6 models @430pts] and [5 models @360pts]
- Skullcrushers = [5 models @400 pts] and [4 models @322pts]
And there in lies the problem. At the higher points total, the Demigryphs could only get 6 of their 7 total models into base contact. That means that one model (in the supporting rank) could only utilize its rider's abysmal offense, while its mount made no contribution. In the case of the Mournfang and the Skullcrushers, they both got all their models into B2B and thus all of their mounts got to attack. Although this only effects the first round, the difference was enough to sway the results.
So personally, 4 things came to light:
- I despise re-visiting and recalculating things, and I will procrastinate when faced with such a scenario
- The model advantage (due to lower points cost) that Demigryphs enjoy over Mournfang and Skullcrushers, breaks down at higher points cost because their models are forced to the back sooner
- Most interestingly, although not tested in this tournament, Mournfang and Skullcrushers are significantly better than Demigryphs when forced to fight from supporting ranks. You never want your MC in supporting ranks, but the Demigryphs are nearly 100% reliant on their mounts offensively, while the Mournfang mounts probably account for around two thirds of their offense, and the Skullcrushers are 50/50 if we exclude stomps.
Anyways, I digress. Back to the topic at hand. Here is my suggested way of handling this situation:
So what do you think of that solution? It seems in my eyes to be the fairest was to proceed (and we finally get to enter a draw into our table of results!!). Agree or disagree?
- the Skullcrusher's victory over the Hammerers stands as is
- the Mournfang's victory over the Hammerers stands as is
The excellent thing we will end up with is an ON AVERAGE listing of the best troops which will be helpful for people playing the troops. Based on their standing, they could work out strategies to tarpit them or power-up one of their units to deal with them etc.
