Articles to print in 3D - Lizardmen / Seraphon
That cerato-saurus is rad. Also those shorts are very in line with the new bloodbowl saurus. I do need to find what Kroxigor proxy I want for my team.
Thanks for the contribution @Lizardtastic . Could you add images to it, so it is easier to find them within the thread?
I thought images will automatically apear with the link. They are in same order.
@Ge32 thanks for the advise on the sculpting I have been working on it in my free time and did a quick little test print and it came out pretty damned good, once I am done I'll post the file.
There is no why, friend. That is what we are here for, to help each other.
Pose A looks fantastic. Now you need to pose it.
Zplugin -> Transpose Master
Tpose Mesh
: It creates a subtool for you and you pose it in the pose you want using masks and the Gizmo.
Tpose Subtool: Once the pose is done, it accommodates all the tools in the position you made.
Then you copy the subtool with the pose you liked and paste it into your work, and that's it. This is how I do the poses in zbrush.
If you find it difficult, I can help you by designing the weapon in Rhinoceros. It is easier to work objects this program. ;)
I've been watching some YouTube videos and noticed that the Lost Kingdom Miniatures are...well frankly massive. They're like bigger than Ogors. What scaling percentage would you take them down to in order to be around a Primaris Intercessor Marine size? I think the Saurus ought to be bigger than a man, on a 28mm (or is GW 32mm scale?) scale but being that huge is a bit much. For WarGaming what scale should I hit?
Hey, man, I have the exact same problem. Have you found any answers?
https://www.lustria-online.com/threads/kroxigor-height.3817/
Tldr; 2.25" tall or ~57mm
That thread gives the dimensions for their height. I would also double check in your slicer compared to their 50mm base size.
In addition here is a pretty good side view from dakkadakka of croxigors behind skinks, scaling them with this comparison in mind could help.
I don't have the specific files your talking about not do I have the official models, hope this helps!
Thanks for the answer. In fact, the only non-hero models I own are the kroxis, who are HUUUUGE, as are the heroes. My main concern is about the infantry. For what I can see on the FB page of the author, my conclusions are 90% for skinks and saurus and 80% for temple guard, but everything just on paper, I haven't tried to print them. And I can't, I just commission them, so I must be sure about the scale if I don't want a full over or undersized unit.
I have the dread saurian file. It has already disappeared. I also have the Oldblood in Carnosaur and the 4-6 Carnosaurs without rider.
Hi! Can you please share a Dread Saurian file for 3d printing? I've been desperately trying to find 3d printed Dread Saurian!
Found these guys on MyMiniFactory, they seem to have some really good Seraphon/Lizardmen proxies, some of which actually look very close to the GW ones. Their Caiman (Kroxigors) are clearly based off of Woogity's designs. Might be worth buying the files if you have a good printer or for someone who can do printing for you.
https://www.myminifactory.com/users/Raven Twin Miniatures
