Chameleon Skink
Alladin the Paladin
I see the melee skinks as a bit of a one trick pony. Definitely starborne only, and you kind of need to invest in cogs and hunters steed (which is fine and all, but you may want to be boosting your Kroak casts instead, and using geminids instead of cogs, for example).
I think they are worth considering for sure, but their benefits are a bit more limited (and the double shooting FoS CA is probably better than the damage you would do in melee if you even make your charge)
