To possibly add to the craziness. I just read on a 40K forum that if an attack turns into multiple hits on a certain dice roll, those additional attacks are considered to have the same dice roll number.
https://www.reddit.com/r/WarhammerC...loding_6s_that_autowound_now_a_thing_in_both/
"From the FAQ:
Q. If an ability or rule generates an additional hit, (e.g. the Imperial Siege Masters Chapter Tactic), do these additional hits gain any other benefits that would apply to an attack on a hit roll of 6 (e.g. an Infiltrator’s marksman bolt carbine)?
A: Yes, the additional hits are treated as having rolled the same value as the dice roll that generated them."
IF this applies to AoS, then the Eviscerating Blade would score LOTS of mortal wounds if you roll multiple "6s" in a To Hit roll (because the extra attacks generated from the "Celestite Weapons" ability of Saurus heroes would be considered to have rolled a "6" as well). An Oldblood, benefiting from a Scar-Vet's command ability and his own Celestite Weapon ability, who rolls even one "6" on an attack with an Eviscerating Blade would generate 3 total hits and 6 mortal wounds!
I'm sure that can't be the way it works... or is it?
