You can make your own UV curing station if you are into DIY projects. I made one using a sheet of plywood, a roll of reflective vinyl (for cars apparently, from Amazon), and this
UV light/turntable. A 405nm UV is what you want, the difference between the 6W and 20W versions in that listing is that the 20W one will cure your models faster, and also bake them faster if you leave them in too long. I think it is worth the extra money to go for the 20W because it saves a good amount of time. I have also heard of people having success making them out of a bucket with a strip of 400-405nm lights all the way around the inside. There are guides for this style of curing station online.
The turntable from that Amazon listing is also serviceable for smaller pieces, but if you take my advice and cure your prints in water then you might want to get a slightly sturdier turntable for the larger pieces. (The bowl of water adds a great deal of weight).
Whatever you do, I suggest you cure your resin prints in a bowl of water. As in cure the print completely submerged in the bowl (preferably a glass/pyrex bowl bowl). This prevents oxygen from getting into the first layer of the print which can stop it from curing properly, in turn causing a tacky finish even if you are cleaning the models properly. I started using water to cure my models and noticed a more "crisp" finish but also got rid of a strange tacky finish that wouldnt go away no matter how hard I cleaned on a small number of models. There seems to be very little information about this in guides and on the internet apart from text posts of people telling others to do it lol.
You can also get a small(3-6L) utrasonic cleaner and use that with your cleaning solution of choice, although you SHOULD NOT use IPA in an ultrasonic cleaner, as there is a heating element in the cleaner that can be a fire hazard, and besides there are other cleaning solutions that are actually cheaper than IPA (and much easier to find in the current pandemic as an added bonus). To see a nice short vid with some cleaning alternatives depending on where you are
click here. Personally I use Mean Green Super Strength. I also put the cleaning solution in a plastic baggie with the resin parts, and then submerge the baggie in water, to save on the amount of solution I use (because you want to fill the ultrasonic cleaner up to a certain line to really get the best effect, and the resin parts will foul the solution quite quickly with the ultrasonic cleaner working).
