AoS Kroak's "Invulnerable" Save Question
Boomer
46
22
8
Kroak has Dead For Innumerable Ages giving him essentially an Invulnerable save after a wound/MW is allocated on a 4+.
An Astrolith Bearer is within 12" of Kroak. This could grant Kroak with what amounts to a 6+ Invulnerable save as well.
Does Kroak get to roll for both of them as long as it's declared which save is being attempted, or does he only get to pick one and roll it?
The wound, save, and allocation rules don't really address this unless there might be an FAQ I missed.
Thoughts?
Boomer
Thoughts?
Boomer
yes you get to roll both of them after saves stack
To justify this to a unscrupulous Skaven player (as they are naturally prone to such things) I assume the stacking applies by way of the AOS general rule of "cumulative" affects and the fact that there is no rule that says you CANT stack them?
Boomer
Boomer
they come from different abilities and unless otherwise stated different abilities stack, if they didn't there would be no way to stack +1 to hit or anything else
