im not saying don't take one.... im saying don't take two lolNote, that EotG is the only means of summoning in Coalesced armies. And with nerf of summoning and buffs on sarurus clubs, I think, EotG still worth considering. He is no worse in combat that standard stegadon and 2 wounds more in Thudner lizard. His mortal wound abilitiy got worse but now you have control of it. My final game with last battletome the eotg kept rolling aoe mw, which got either wasted or failed on 4+. And, more importantly, it works in the shooting phase and can be laucnhed twice for CP in thunderlizard.
That is what I get for trying to use the Italian language point sheet. lolStarborn shadowstrike is 170 points eachstupid expensive...
Check fbThat is what I get for trying to use the Italian language point sheet. lol
Danke DankeCheck fb![]()
Very true. It is highly skill demanding to place your unit in the right spot. It will generally take two turns to set up. Keep in mind that charging is a movement and so is pilein. So you can simply charge and if you roll high enough zig back and forth over the unit with each model. Cogs and the Skink Priest help a lost. Considering replace the Slann with Starseer to get 3d5 charge.Hi LizardWizard and thanks for sharing all your list.
I have the feeling you like terradons. To my point of view they are very hard to play now since you roll for MW only for models "that passed across any models from that ennemy unit". I understand the 2+ with terradon chief but i am pretty sure that not all of the models will fly over ennemy. Then all the rest of your MW dices will be lost.
Even for with the cost reduction it seems pretty hard to make them worth it.
I will be walking up field with run and charge and +3" move FoS and Cogs.Assuming you appears at 9" , 3d6 = 10" average, 11" with charge bonus, i am pretty sure it is impossible to set 12 terradons base perfectly at 9", even worse to make them zig on the target, with a 2" marge. It also means that any trash unit can protect against them.
If you do not appears at 9", even with 16" move, i am pretty sure they will be washed before coming close with a 6+ save.
With previous shadowstrike, it was already physically painful to put 12 rippers/terras in contact.
We ll see on table i guess.
Agreed! They are cheaper flying-and-once-per-game-MW'ing RazordonsTerradons are worth so much more than just their bombs. Especially in coalesce shadow strike.
you can get them +2 to hit, run shoot and charge and wounds of 6+ are a mortal wound.
just take their shooting attack after you move 18-23”. 12d6 attacks hitting on 2+, wounding on 3+. Then 6s are mw. Then you can charge, bomb and have 60 attacks hit on 2+ or 3+... again 6 to wound is mortal wound. It’s insanely good, not just for the bombs
Thunder Lizards/Thunderquake/coalesed
Allegiance: Seraphon
-Coalesced
-Thunderlizards
Leaders:
Engine of the Gods (260)
Skink Starpriest (120)
Skink Priest (70)
Battleline:
10x Skink (60)
- Boltspitter & Starbuckler
Stegadon (240)
- Weapon: Skystreak Bow
Stegadon (240)
Units:
6 x Kroxigor (280)
Behemoths:
Bastiladon (220)
- Weapon: Solar Engine
Bastiladon (220)
Total: 1710 / 2000
Extra Command Points: 0
Allies: 0 / 400
Wounds: 78
Still rounding this one out. Gonna take the Thunderquake battalion pretty sure.
Koatl's Claw Sunclaw Temple Host
- Coalesced
- Koatl's Claw
Leaders
Skink Starseer (140)
- General
- Command Trait: Master of Star Rituals
- Spell: Hand of Glory
- Spell: Celestial Harmony
Saurus Sunblood (130)
Saurus Astrolith Bearer (140)
Saurus Scar-Veteran on Carnosaur (250)
- War Spear
- Artefact: Eviscerating Blade
Battleline
40 x Saurus Warriors (320)
- Spears
- Spears
20 x Saurus Warriors (180)
- Clubs
Battalions
Sunclaw Starhost (180)
Bound Chronomantic Cogs (90)
Bound Emerald Lifeswarm (60)
Bound Geminids of Uhl-Gysh (70)
Total: 2000 / 2000
Extra Command Points: 1
Allies: 0 / 400
Wounds: 134
Not wild about 2 Wizard and 3 Endless spells. Specially when I will want to cast the on scroll spell for both wizards frequently.
May I ask why you made the Starseer the General rather than the Scar-Veteran? Would rather see a Saurus list led by a Saurus personally
