Ok, i was going to shut it down, but i see you guys already stepped back.
Good.
ONE
Obviously you all need to abstain in calling "liar" and "cheater" other forumeers, or to use terms as "pathetic".
Even if you're right, you don't want to receive a warning, right?
TWO
On this forum we DON'T support cheating or unfair behaviors.
In the past we had a thread with a poster that tried to actively support cheating. It won't happen again, I promise you.
This thread is going into that direction, as the "trick" proposed by the OP is not illegal per se, but it's at best poor sportsmanship, when done on purpose.
So no, this kind of "game hacks", when it happens once because you were distracted, is ok. If you suggest it as if it were a fine tactic, is NOT ok.
THREE
Should i lock this thread?
maybe, or maybe not. i think we can still debate about ways to take advantage on your opponent.
But they must be fair ones. To give false suggestions is not good, but to play mind tricks is perfectly fine.
An example could be to put in a visible position, in your "summoning rooster", the miniature of a model that you don't intend to conjure, but in this way you can lead your opponent to wrong evaluations.
If we want to discuss such kind of things and tricks, the thread still got a purpose.
