Shadow Angel
If use the LoST ability on a unit of eternal saurus guard will they still get the D3 damage buff?
Yes. LoSaT does not count as a movement. Movement is anything that requires the unit to move along the table. LoSaT removes them from the table and then replaces them onto it.If use the LoST ability on a unit of eternal saurus guard will they still get the D3 damage buff?
But doesn't LoSaT say that it count as that units move for the next move phase?Yes. LoSaT does not count as a movement. Movement is anything that requires the unit to move along the table. LoSaT removes them from the table and then replaces them onto it.
noBut doesn't LoSaT say that it count as that units move for the next move phase?
Has there been a faq on this?I understand what your linking. the answer is still no. its a replacement for movement, it is not movement itself.
Well, the Gnawhole has the exact same wording for counting as the unit's move. Also, consuming an action is not the same as using one. Movement and replacement are different.Has there been a faq on this?
Alright, it just seems wierd to me when it specificly says that it count as their move.Well, the Gnawhole has the exact same wording for counting as the unit's move. Also, consuming an action is not the same as using one. Movement and replacement are different.
frequency of relevancy wasn't the point of the comparison, it was simply showing that models can be moved without it actually being a "move" movementBut it will rarely make a difference for the saurus guard anyway the turn they teleport, since they only get the bonus in their own combat phase
that's not true at all. they can Losat, get a +2 charge from cogs, make the 7" charge and have the damage bonus on the seraphon players turn.This!
The unit can never LoSaT and get into combat the same turn to have the damage buff anyway.
And since it's only bonus in your combat phase it changes nothing. You need the unit of guard to get charged, survive your opponent's turn then hit back your following turn for it to ever be a thing.
Pretty sure the affect says that they cannot have moved in either the movement or charge phase. I left my book at the clubhouse though, so I can't verify my memory.that's not true at all. they can Losat, get a +2 charge from cogs, make the 7" charge and have the damage bonus on the seraphon players turn.
you can 100% losat and have the bonus in the same turn.... its just not likely.
CorrectPretty sure the affect says that they cannot have moved in either the movement or charge phase. I left my book at the clubhouse though, so I can't verify my memory.
We all miss things. You caught me last weekoh I was unaware it said charge phase too. my bad.
