TrevBot
Hello all!
I had my first few games this weekend and had a ton of fun!
Game 1 (1,000 Points) : Seraphon vs Blades of Khorne
My list was terrible here, I just wanted to run as many models as possible that I had available in a list. I was also really excited to use both a Carnosaur & Bastiladon.
Battleplan: Shifting Objectives
Not sure if this was the exact name, but the one where you roll at the start of each round to see which objective is worth 3 points and the other 2 are worth 1.
**Setup**
Turn 1: Blades of Khorne
He took first turn, and ran up to get as close to each of the 3 objectives as possible. With his big block of 40 heading right towards the 3 point objective in the middle. However, terrible run rolls prevented him from getting within 6" of any objective.
Score: 0 - 0
Turn 1: Seraphon
Buffed Carnosaur with Skink Starpriest (Celestial Rites + Serpent Staff) then use LoSaT on Star Priest to get him into range of the 40 block of Bloodreavers. Attempted to cast Stellar Tempest and had it unbound by Flesh Hounds.
Moved all units of skinks to be just barely within 6" of all 3 objectives. Moved Carnosaur to about 10" away from Flesh Hounds.
Shot Flesh Hounds with Bastiladon + Oldblood to bring the unit down to 1 model. Shot Garreck's Reavers with Skinks and CLEARED the entire unit.
Failed Carnosaur charge.
Score: 5 - 0 (Seraphon)
Turn 2: Seraphon (DOUBLE TURN!)
Was super excited to get my double turn. I ended up using LoSaT on my Carnosaur to get him 9" from Bloodsecrator with intent to charge it. Buffed Razordons this time with Skink Starpriest. Attempted (and failed) ANOTHER cast of Stellar Tempest on Bloodreavers.
Moved Razordons slightly up behind a unit of Skinks barely within middle objective, everything else stayed in place.
Shot Blood Warriors with Bastiladon doing 5 wounds. Shot Bloodsecrator with Old Blood for a big ol' whiff. Every Skink missed their shots. Razordons were not in range.
Whiffed my charge for Carnosaur, leaving him now in range of the remaining Flesh Hound.
Actual Score: 10 - 0 (Seraphon)
Another rule oopsie. My opponent was adamant that points only accrue at the end of BOTH turns.
Turn 2: Blades of Khorne
He used 5 blood to cast Brass Skull Meteor on my Skinks, Razordons, Starpriest doing several mortal wounds to each. Then used 5 blood to reinforce his unit of Flesh Hounds. Then another 3 blood to summon a Skullmaster near my Carnosaur.
He also wiped 3 units of skinks and was now within striking range of my Bastiladon, Razordons & Starpriest with 30+ Bloodreavers and 8 Blood Warriors supported by a Bloodstoker, Korghos Khul & Bloodsecrator.
Score: 5 - 2 (Seraphon)
Actual Score 10 - 2 (Seraphon)
Turn 3: Blades of Khorne
I went ahead and conceded at this point after he got the double turn.
Conclusion:
I was sad learning later that after you spend blood tide you lose ALL of it. Also we did points wrong, I wouldn't have conceded this game and had a much better chance at the battle if things went as they should. Plus my mistake with the cloak meant deep striking my carnosaur was a dumb, dumb move.
Up next, a much more even battle with Lizardwizard's Shadowstrike 1k List!
EDIT: I made a silly MSPAINT mockup for each round!
(Also JOHN MADDEN!)
- Blades of Khorne vs Casual Shitty List
- Blades of Khorne vs Shadowstrike
- Nagash list vs Shadowstrike (Silly, silly match)
Leaders:
- Skink Starpriest (General)
- Master of Star Rituals
- Stellar Tempest
- Saurus Oldblood on Carnosaur
- Doppleganger Cloak
- Skinks x 10
- Boltspitters + Shields
- Skinks x 10
- Skinks x 10
- Skinks x 10
- Razordons x 3
- Bastiladon
Leaders:
- Bloodsecrator (General)
- Korghos Khul
- Bloodstoker
- Blood Warriors x 10
- Bloodreavers x 40
- Flesh Hounds x 5
- Garrek's Reavers x 5
**Setup**
Score: 0 - 0
Turn 1: Seraphon
- We later learned this was MASSIVELY wrong. He also summoned these outside of the 12" range of a hero.
Conclusion:
(Also JOHN MADDEN!)
