Scar-Veteran
Sudsinabucket
No problem man! Just took me by surprise after creating/visualizing what I think is pretty great (minus the extra space which does kinda kill me), I apologize if I snapped back, just took me by surprise.I have a bunch of spare 51mm rounds (empty 2 inch D&D / RPG bases).
I apologize for raining on the parade a bit. Sometimes I let the laws of physics crush the Rule of Cool. But I am inclined to paint one gold also.
But maybe not solid gold.Gold is heavy.
Here are some quick back-of-envelope calculations with the help of google and web/based converters.
25mm Base
That is a 5 foot diameter, 3/5ths of a foot deep cylinder. 11.78 cubic feet volume.
14,208 pounds
6.44 Metric Tonnes (If solid gold)
60mm Base
That is a 12 foot diameter, 3/5ths of a foot deep cylinder. 11.78 cubic feet volume.
80,809 pounds
36.65 Metric Tonnes (If solid gold)
Krox are strong but 6-36 tonnes ???
I have been contemplating attempting this conversion also which is the reason for my interest in the thread.
I would be happy to send you a 50mm round by post. If you think that will help with the blank space problem.
Next question: have you given any thought to what the reverse side will look like?
I appreciate the physics and real life look at it, part of the reason I did the 60mm (aside from it being the best option that I have atm) is because I have 3 (they came with my Mierce Salamanders) so I was able to glue two together to make both back and front look the same instead of a big dip in the back. I also really want the Carno Head coming out from it, so figured a bigger size would be more realistic when summoning large creatures (as it is a Beast/serpent oriented astrolith banner). As for the weight...fuck, yeah a Krox would probably have an issue lifting that up for sure now that the math (im not strong in at all) is infront of me....which also means my Kroxi driver from my Thunderlizard is probably also not super realistic as its neck is going to be moving at more than 6 tonnes of pressure on the low side lol ah well
As for the back side....something like this I was imagining. Going to clip off the spear heads so the two stick together back to back so its not AS crowded
I would love the 50mm (or 2 if able?) if you are willing! Id like to see the difference for sure, and if it works out Ill buy a second one to glue together whenever I have a job again/am not constantly in the hospital like the past 3 months. If the 50mm rounds are better....maybe ill turn the 60mms into a spawning pool? Could be awesome
Edit: I just noticed you said to move bits inside the base, the bottom picture shows how that would look. I was already debating that, they just arnt glued on atm and dont rest easily on the edge where Id want em
