So you can condemn the Nighthaunt for lack of originality, but Fyreslayers get a pass because the fantasy Slayers which they were based off of was a somewhat original idea 25-30 years ago?The Fyreslayers themselves are not the most original thing in the world, no, but the whole concept of a Slayer is, for GW were the first to think of the idea of a Dwarf who has shaven his hair into a Mohawk, dyed it orange, and then goes off into the wilderness seeking a glorious death. The only things I’ve seen from other fantasy wargames companies that are remotely close to Slayers are either copies of them released specifically to allow players to still be able to buy, make and paint and use some in their games since GW killed Fantasy (in the case of Avatars of War) or versions that bear a similarity to them but are not the same lorewise (in the case of Mantic’s Dwarf Berserkers, who are more like Dwarf versions of Viking berserkers whereas Slayers are more like Celtic Fanatics).
In terms of the models themselves, the Nighthaunt are more original when compared to their classic WFB counterparts than Fyreslayers are. Fyreslayers are direct copies of fantasy slayers. Zero originality.
This is completely irrelevant. We are discussing the aesthetic value of the models themselves, not their fluff.Furthermore, the Fyreslayers are not simply direct carbon copies of Slayers made specifically for AoS - one of the things I like most about them is that they are a development, an evolution, of Slayers from a deranged cult as part of a wider faction into a faction of their own right. They now have a way of life based upon that of the old Dwarfs, while at the same time retaining the Slayer tradition of fighting more aggressively than defensively. So they aren’t the same thing as Slayers at all once you delve beyond the familiar exterior.
Nighthaunt have none of that - they aren’t even an extension of Grim Reapers, they are just AoS Grim Reapers made from discontented souls in Nagash’s underworld. No more, no less. They have no culture or religion, nothing that the Fyreslayers have which set them apart from the old Slayers.
As for the unit diversity, that was the fault of the old GW that killed off Fantasy and brought in AoS, as they wanted to bring in new factions as quickly as possible to try and calm the tide of AoS hate coming from Fantasy player all around the world. All the other First Edition factions have a similar problem. If the Fyreslayers had been released in Second Edition, they would have probably had a lot more unit choice to them, and GW may well give them those new units when they’ve finished giving all factions a tome like they did last year with 8th Edition 40K.
So which of the other first edition factions are as monotonous and boring as Fyreslayers. The entire army (other than the very average monster) is pretty much the exact same thing. Nighthaunt have infinitely more depth and range.
To be honest that’s not the best comparison. The skull-faced banshees on Lady Olynder detract from the grace of Olynder herself (who is based on another unoriginal trope that probably stems from Miss Havisham in Great Expectations).
The skull faced banshees are just fine. You don't like them, that's fair enough, but they were readily accepted by the community with far more positivity than that crotch monster. You literally have a little boney guy sticking out of the monster's crotch and you're criticizing the face of the banshees!
Also, what is with the extreme obsession with originality? Everything draws inspiration from something else. Your beloved Fyreslayers are copies of fantasy slayers which in turn are a tweak on dwarfs (which is hardly original). There is nothing wrong with an artistic take on a classic aesthetic/theme. Would you condemn all of Bretonnia because they are a rehashed version of knights in shining armor? By the same token, Lizardmen are hardly an original concept.
No, the crotch monster is simply the worst offender. The whole model looks terrible. If it was only something so trivial, I don't think there would be nearly as many complaints as we currently have floating around.The only thing that is really bad about the monster, by contrast, is the skeleton in the crotch, and as I say before, THAT LOOKS AS THOUGH IT CAN BE EASILY REMOVED.
Any model can be made to look good with extensive enough patience, work and greenstuffing skills. We're judging the models as they are, not as they could be after they are painstakingly re-imagined and re-worked.You don’t have to have the thing as what it comes as on the box, you can quite easily clip the arms off and probably file the head off or greenstuff over it.
