Fantastic beastie roaming through the trees!
Do you plan to add a bit more undergrowth at the bases of the trees?
Thank you! Still trying to stick with the vibrant theme! Need to do some dry brushing and highlights on the scales and spine. Thinking Kindlerflame for the orange areas, not sure on the blueAwesome cold one color scheme!
Ended up doing just a light skink blue on certain areas and am thinking of doing another very light coat of the contrast again to give it that very subtle differenceI like the blue color, it does look pretty cool, but if you find something you like more then go for it
I think that will work.Current Work up for my idea of an Astrolith Banner on a 60mm disc. I guess I dont totally know the lore behind it, but I vire it as a gateway and a magic enhancer. My vision was a Astrolith Banner of "Beasts/Serpents" with a Carnosaur being summoned to the battle field. The Banner itself is kinda big, was originally planning on putting it on a Cold One rider or Oldblood body, but now thinking of maybe a Kroxigor? Ill see what works best I suppose, could even Mount it on a beastie!
What do yall think? Nothing is glued down yet, just wanted to see how it could lookView attachment 59382 View attachment 59383 View attachment 59384
Which one do you think would be best? Lots of options there, haI think that will work.![]()
I like the one with the Carno-head.Which one do you think would be best? Lots of options there, ha
Is a 25mm the size the saurus are placed on? If so, the Carno head wouldnt fit well with the other decorations, I do agree about the dead space. Im just using left over pieces I have left. Was thinking of doing designed with elmeber glue and then painting them, but eh...I like the one with the Carno-head.
But all of them look sorta empty. There is lotsa flat surface on the disk.
About the size of the disc. A 25mm disc is five feet across in real life. A 30mm disc translates to 6 feet. A 60mm disc is a 12 foot diameter circle.
The size of these things disturbs me a bit.
Maybe go smaller? Move more of the gibbons inside the disc?
What is the astrolith made of?Not sure why the size matters?
Bronze? Does Lith = Stone? Imagine a disc made of either material 12 feet wide and about 8 inches thick. Imagine trying to lift that or stand it on a pole. It would weigh hundreds of pounds.
Maybe it’s made of pumice or paper maché ?
~~~~~ that’s ^ why ~~~~~
Do you have a 40mm disc?
Thank you! I for the most part am very happy with how its turning out... however, I am not totally sure about the dead space either. Part of me is tempted to use liquid water to make a "summoning" effect under the Carno head, may look into it as ive never done that and am not 100% sure how to make that happenMy favourite is the one with the Carno head, too.
As for what to do with the size and the resulting empty space.... no clue.
I apologize for raining on the parade a bit. Sometimes I let the laws of physics crush the Rule of Cool. But I am inclined to paint one gold also.No, I do not Im using left over parts that I have as I stated.
I was imagining it being made out of gold, and I find it hard to believe that a Kroxigor or some beast would have an issue holding that up on some sort of strong support, both are raw muscle.
