Canas
Ninth Spawning
For our teleport & summoning I'd actually dump the range requirement and instead give us a different disadvantage in the form of a fairly significant debuff. I'd rather we suffer say -1 on all our combat and casting rolls after summoning/teleporting, but can actually get in the correct position than the current arbitrary range requirement that is either completly irrelevant in case you can shoot or have a charge modifier or leaves you unable to actually do anything that turn.
Your conjuration is better than the current one. I'd avoid the randomness of the D3. And I'd include spells/command abilities/prayers/artifacts/etc. to help improve it. The general idea of drawing lay lines I like. Numbers will obviously need tweaking.
For made of star stuff. Making them better when away from our wizards is probably going to be a pain to play around. Especially considering our wizards can't defend themselves against anything and we rely heavily on synergies requiring us to be near them. Also, it doesn't really make intuitive sense as a rule representing reality but seems more an arbitrary rule made to balance the game. The idea itself of not being allowed to turtle can be interesting though, but would require us to be vastly less dependent on synergies & sticking together.
As for the mount traits. I think some of them might be too clearly the best pick in most situations.
Also, bread is a baguette or a sandwich. Bred is the verb you're looking for.
