As per the title.
As per page 113 of the BRB
Since Skinks are not monstrous infantry/beasts/cavalry or a monster (and they are not obstacles), they have no effect of stopping a cannonball shot. As a result, if your monster is within the path of where the cannonball first lands and eventually comes to a rest, it is hit, regardless of any poor skinks that get in the way.
Now I agree that skinks can’t take a cannonball. But what if the skinks are blocking line of sight to the spot the cannon crew are aiming for? I mean using TLOS rules means if they can’t see then they can’t shoot right? A cannon crew never actually aims directly at their target (unless they do and run the risk of overshooting) and I can’t find anything in the rules to suggest otherwise
You're right, although in an actual game it will be very difficult to block true line of sight with skinks. With true line of sight it is pretty difficult to obscure a target with models. Remember that the cannon can choose a skink it can see as its target and then bounce through to its intended target. I suppose if you had and extremely deep unit of cohort skinks that were angled just right, you might be able to obscure the ideal point of impact. Of course, if the cannon is elevated even a bit it will be easy to see right over the skinks.But what if the skinks are blocking line of sight to the spot the cannon crew are aiming for? I mean using TLOS rules means if they can’t see then they can’t shoot right?
Can't speak directly for 8th ed, but the previous two editions large monsters were also large targets?
There were three category of miniature sizes: small (like swarms) that could not block line of sight for medium creatures (like regular human-sized infantry; ogre sized models were also in this category) which in turn could not block line of sight for monstrous creatures (like dragons, stegadons/carnosaurs, giants, etc). You could only block line of sight for creatures in the same or smaller category, not bigger.
It doesn't make much sense for a 4 foot tall skink to be able to block an archer some distance away from firing his bow (or an artillery crew from firing a cannonball) at a 40-foot-tall stegadon.
Now if there was a bit of terrain in the way (say, a house or castle wall, or maybe something natural like a hill) then that should block line of sight.
All in all, I just don't see it as a viable option in an actual game. Theoretically possible... yes, but practical/useful... I'd say no.
That’s just it, when you fire a cannon you don’t actually aim it at the monster. You aim it at a spot on the ground. Large target doesn’t come into it as the monster isn’t your target.
Hmmmm, so for example:
C
SSSSSSSSS
SSSSSSSSS
X
10”
v
M
C = cannon
S = skinks
X = spot the cannon is aiming for
M = monster
Surely as long as C and X are on the same level, the cannon can be blocked reliably from anywhere on the battlefield in this way? As long as the skinks are more than 10” away from the monster and between the monster and the cannon? Would you be happy to allow your opponent to shoot through the skinks without penalty?
Keep in mind that you don't have to aim at a spot on the ground, you do so because the cannonball overshoots...That’s just it, when you fire a cannon you don’t actually aim it at the monster. You aim it at a spot on the ground. Large target doesn’t come into it as the monster isn’t your target.
The problem lies with true line of sight. If you can take a laser pointer (placed at the cannon's muzzle) and shine it through the unit of skinks at the spot you wish to aim, then you are permitted to do so. BS skill shooting would suffer a to hit modifier when doing so, but the cannon would not. As I said earlier, it is theoretically possible, but it will seldom work out in an actual game setting.Hmmmm, so for example:
C
SSSSSSSSS
SSSSSSSSS
X
10”
v
M
C = cannon
S = skinks
M = monster
While per the rules mechanics it appears you are aiming at a spot on the ground, I am pretty sure the intent remains the same; i.e. the cannon crew is still attempting to shoot down the big beastie (the target) and not the distraction (the skirmishers up front). Due to the size difference between basic infantry and a large target, regardless of the distance between them that monster is still one big honking creature.
I am probably not the best person to ask, in most weird cases like this as long as me and my opponent (who 95% of the time was my brother) we would just do what made most sense.
I would say cannon crews go ahead and shoot at the big monster rolling up in the rear, OR fill the cannon with grapeshot to clear out all the skirmishers up front (that still a rule too? It used to be cannons had two types of ammo I think).
Or better plan, the cannon's general needs to deploy his cannon on top a hill in order to really take advantage of the artillery piece.
Personally I don't particularly like the way that cannons operate in 8th edition. However, in the context of this discussion, I'm just providing what I feel are the relevant rules of the game, whether or not I like them or not. I'm not aware of any rules that prevent a cannon from shooting through a screening unit if it can draw true line of sight to its intended target.I would argue if you are talking about what makes sense - it doesn’t make sense to be able to shoot a cannonball through a unit unscathed.
Are stegadons really 40 feet tall?It doesn't make much sense for a 4 foot tall skink to be able to block an archer some distance away from firing his bow (or an artillery crew from firing a cannonball) at a 40-foot-tall stegadon.
Calculates
The chariot base is twenty feet long. Stegs are less than two chariot bases tall.
Agreed, the thread has spiraled off topic.I think a lot of people are missing the point a little bit. Sure, you can see a Stegadon over the top of some skinks. By my point is you can’t see the spot on the ground that you’re aiming for.
This is because eighth edition is all but gone (sadly) and its cannon rules are (tragically) too ridiculous to bother discussing.Agreed, the thread has spiraled off topic.
Real cannons don’t fire at points on the the ground. That has-had nothing whatsoever to do with the operation of cannons. Nothing.I think a lot of people are missing the point a little bit. Sure, you can see a Stegadon over the top of some skinks. By my point is you can’t see the spot on the ground that you’re aiming for.
Nevermind the Skinks. The Monster certainly blocks LOS to all points on the back edges of its base.My opponent ALWAYS aims his cannons 10” from the back of the monsters base. So he isn’t now actually aiming at the monster at all, In this case he is aiming at the spot on the ground - which is the size of the cannon ball itself (so a few mm diameter?)
This is because eighth edition is all but gone (sadly) and its cannon rules are too ridiculous to bother discussing.
Did you mean the nearest edge(s)?![]()
