AoS Krox and Steggy TQ for Slikus Vaw
OldBlood
LizardWizard
Grand Skink Handler
4,286
9,466
Here is a Thunderquake list for @Slikus Vaw
2000pt Thunderquake w/Krox & Steggies
Allegiance: Seraphon
- Mortal Realm: Aqshy
LEADERS:
Slann Starmaster
(260)
- General
- Artefact : Ignax's Scales
- Spell : Stellar Tempest
Saurus Astrolith Bearer (160)
Engine of the Gods (240)
- Artefact : Ruby Ring
Skink Starpriest
-Celestial Apotheosis
UNITS:
6 x Kroxigor (300)
- 2 x Moonhammers
20 x Skinks (140)
10 x Skinks (70)
10 x Skinks (70)
BEHEMOTHS:
Stegadon
(200)
Stegadon (200)
BATTALIONS:
Thunderquake Starhost
(120)
ENDLESS SPELLS / TERRAIN:
Chronomantic Cogs
(80)
Balewind Vortex (40)
TOTAL: 1960/2000
EXTRA COMMAND POINTS: 1
WOUNDS: 117
I hope this is helpful. This list should preform fine for small RTTs of 10ish players. I would definitely switch to a more standard Bastiladon & Razordon TQ for larger or 2day events.
i just dont have enuf unit knowledge atm so i wouldnt be able to use the shadowstrike as effective.
LEADERS:
Slann Starmaster
(260)
- General
- Artefact : Purefire Brazier
Skink StarPriest (80)
- Spell : Celestial Apotheosis
UNITS:
10 x Skinks (70)
10 x Skinks (70)
10 x Skinks (70)
6 x Ripperdactyl Riders (280)
1 x Razordons (50)
3 x Skink Handlers (40)
BEHEMOTHS:
Stegadon
(200)
Stegadon (200)
Troglodon (140)
BATTALIONS:
(120)
Shadowstrike Starhost (180)
Endless Spells / Terrain:
Balewind Vortex
(40)
TOTAL: 1960/2000
EXTRA COMMAND POINTS: 2
WOUNDS: 104
It doesn't feel worth it to me to combine the two. You could use Terradons and take 3 Krox. Maybe that would be better. It is certainly a Skink themed list.
hows this list?
LEADERS:
Slann Starmaster
(260)
- General
UNITS:
10 x Skinks (70)
10 x Skinks (70)
10 x Skinks (70)
3 x Ripperdactyl Riders (140)
1 x Razordons (50)
BEHEMOTHS:
Stegadon
(200)
Bastiladon (280)
BATTALIONS:
(120)
Balewind Vortex
(40)
TOTAL: 2000/2000
WOUNDS: 90
Give it a try. 3x Ripper Shadowstrike normally doesn't do too much in my experience, but with the all the shooting it might still work well enough.
thats what i was afriad of. but will give it a try once i get those rippers. if im able to get the EotG summon should i do 3 rippers with this list then teleport them over?
if you drop the basti down to a second steg you will have 80 points to play with, and two stegadons can move each other after a teleport to be in combat on turn one. essentially you would convert this list to full balance... a nasty alpha strike (2x stegadons and the 3 rippers) essentially anywhere on the board you want it. with the 80 points left over you can throw in Cronomatic cogs and now you have a slann to summon more baddies in on turn 2/3 or whenever (depending on how well your alpha goes). essentially this one small change gives you a little less shooting initially, but gives you both the IN YOUR FACE threat of an alpha turn one AND the versatility of a summoning list
only bad thing is you are 5 drops. Slann, AB, TQ (steg steg EoTG razor, handlers) SS (StarP, 2x skink, rippers) and then the last unit of skinks
Ilkain, do you think a 8 to 3" charge is safe enough for a tournament? I am bad at dice rolls, so I always try to minimize risk.
you have to treat it as a mathematical average. so your charges should be calculated as if they will be 5" in that situation (4" is 50% of 1d6). and yes I think 5" on 2d6 (average 7) is a safe bet.
Ok I hope he's lucky then. Just happened too often to me and if 50% of the stegs fail the charge, they might get wiped out.
True. If it fails a charge after rolling a 1 in the hero phase, the 8" range is not enough, so the less the failed charge distance is, the more models can be flame grilled.
I mean... 1's are always bad (except battleshock) so yeah... but the math is sound lol.
i do definately like this idea nd will try it out just need some rippers :) wish they would have reduced the point value of the handlers they r almost useless lol
the 5 drops aint too bad of a thing for me. ive been doing good deployments. but i also wont get any rerolls for my TQ until i can get EotG nd AB in range prolly soonest 2nd turn unless i take the second priority nd have them move forward nd then they might be in range for some runs from the EotG nd AB. a double turn would be devistating tho
