AoS Line of sight ruling clarified
Skink Chief
ILKAIN
1,845
3,389
there was some discussion not too long ago about Prismatic palisade and LOS. if you read the new "Runic Fyrewall" for the Fyreslayers the way they define LOS is perfect. "a model cannot see another model if an imaginary straight line, 1mm wide, drawn from the center of its base to the center of the other models base pases within 1" of this model."
that's the wording we need on the palisade, and an additional text line that prevents melee if it doesn't have a line matching the same criteria
This is the same definition applied to one of the conditions you can have when you play in the realm of Aqshy.
but is not the definition used by the rules to determine if you see a model or not… so (until the base rule will be clarified or modified) it applies only to certain special effects or spells as the Runic Fyrewall.
I know... I just wish they would apply it to the core rules lol
Melee in general really needs it.. it's hilarious that you can stab through solid objects...
